move the cog a little more foreward will stop alot of the bouncing, move trim tabs down a little will help too (:
My VERY Fast SV27!!!!
you could raise the strut a little move it up some, it will be faster good luck, papaTHUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVESComment
ive already lowered the trim tabs a bit since last run. i knew about the COG problem last time i was out i just didnt have velcro in the right spots in order to move my batteries up. Problem fixed now though. Next run will be with my 12l and 180a esc hopefully. Think i could run a p220 prop with the 12l and the stock esc?Z
KBB34" Mono - Fast
ToySport Triton- Not as fastComment
LMT
LehnerMotorenTechnik.comComment
hell yes just put it on max speed and off u go hold max speed achieved
gives you distance travled and elapsed time great great gadjetTHUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
Sweet, I need one bad Iv been thinking about what the exact speeds are on my white SV.
Here's the motor and esc I have laying around for your UL-1...
The motor is new and came straight out of the G-force a-z hydro, and has been ran 1 time.
This motor ran well on 4s and an x440.
The esc has been ran about 15 times on 4s, and works OK... The problem is, I can't ever seem to get it to program right the first time i plug in the batts,
I always have to pull the power to the reciever then plug it back in, then it seems to beep once like it was suppose to... anyways It does work but thats the only issue.
Id take $70.00 shipped for the motor and esc onlyLMT
the cooling jacket is made on to the motor do you have missing fittingTHUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
