Wait a minute...2 4S packs in parallel?!?
this adds a bunch of weight, I usually use 2 2S packs in series.
more weight and longer runtime will likely fry that Ammo or your ESC or both with anything larger than 40mm...and even then, it's too much for that high KV motor.
Running 2 4S packs in parallel (10,000mah) isn't going to get you twice the runtime of 2 2S packs in series (5000mah). The extra weight and load on the motor will use up more capacity at a higher rate, not to mention stress the system and slow the boat.
2 2S packs is really the best way to go with this boat IME.
I'm betting noone who gave you prop advice is running 2 4S packs...that means their info is not going to help your boat with it's 8S onboard.
with what you wrote egneg.
