I just purchased a "lightly used" SuperVee 27 off eBay. Everything appeared to be in good shape and checked out when I dry-tested it (radio system works fine, ESC boots up and works fine, etc.) I took it to a local pond today and it got up on plane nicely but it cut out after about 2 seconds of being on plane. I got just a short blip of throttle out of it after that and then it died. Of course I didn't bring any retrieval equipment with me, so I got a bunch of twine with a weight on the end but it was too far out to catch. I let the current carry it in, but as it got closer to the shore I noticed it was lower in the water than it was. It got within 20 feet of the shore and I got to watch the nose go straight up and the boat sank into the water (with bubbles and everything). The floaty foam did it's job and the nose stayed above the water, but it took a while to get it back.
As you can imagine, I'm a little upset with my boat. First off, is it normal for them to simply cut out during a run? The batteries were fully charged, my antenna was fully out, and I turned the radio off and on a few times trying to reboot the ESC but it didn't work. I've tried to get it to shut down again since then but it all works perfectly.
I dried everything out and it all still works, so I put it in a bath tub full of water and came back in 20 minutes to find it was already taking on water. When the boat is moving I'm sure it won't take on any water and since this boat is made to be either moving or not in the water I figure this isn't too bad of a thing (until your ESC or radio dies) but I don't think a boat should take on water at all. I sealed up where the outdrive tube goes into the hull (sorry, I'm not too familiar with all the nautical terms) with some Shoe Goo, but it still seems to be taking on water. Could it be coming in through the screw holes for the trim tabs?
Any help would be greatly appreciated, this thing seems like it would be so much fun if it didn't sink
