BEC red wire disconnection
  • raymund629
    • Jun 2008
    • 28
    I just received the 4 cell receiver pack from OSE. I want to run 2 7 cell battery pack. Now i'm confused which red wire should I disconnect from the BEC. Should I disconnect the red wire from CH. 1. CH. 1 wire goes to the servo. Or should I disconnect the red wire from CH.2. CH. 2 goes to the ESC.
  • Ub Hauled
    • Aug 2007
    • 3031
    are you running the packs in series or parallel?
    if you run them in series then remove the red wire for the ESC cable, or get an extension cable
    and cut the red wire tip from that to avoid damage to the ESC cable).
    • raymund629
      • Jun 2008
      • 28
      Hi! Im sorry I don't know about series or parallel. I have just a stock SV27. I just don't know which red wire should I disconnect. There are 2 red wires. A red wire on channel 1 which goes to the servo and a red wire on channel 2 that goes to the ESC.
      Is it the ESC that should be avoided from damage? If it is, then its the red wire from CH. 2 that should be remove.
      • rockwerks
        • Jul 2008
        • 772
        Yes you need to disconnect the red wire from the esc to the receiver, you can use a toothpick and remove the metal clip from the plug that goes into the receiver. then just tape the wire back out of the way
        an RC rock crawler lost in a sea of boat parts.........
        • raymund629
          • Jun 2008
          • 28
          Now I understand. Thank you so much!
          • dr. hook
            • Apr 2009
            • 26
            I just recently purchased a castle bec from my LHS so I can run 7cells. Does this method apply the same for the bec instead of using the receiver pack??
            • line6
              • Aug 2008
              • 478
              Yes, with the castle bec you need to pull the red wire from the esc to the rx
              • dr. hook
                • Apr 2009
                • 26
                Oh okay sweet thanks!
                • dr. hook
                  • Apr 2009
                  • 26
                  Which port on the receiver do I connect the plug from the esc? Is it the battery port or channel 2?
                    • 9488
                    Sounds like you have done this before..
                    Great idea!
                    • dr. hook
                      • Apr 2009
                      • 26
                      Oh sorry I meant the plug from the "BEC" not esc LOL!
                      • line6
                        • Aug 2008
                        • 478
                        #1 Servo
                        #2 ESC
                        BEC goes in the BAT Ch.
                        • dr. hook
                          • Apr 2009
                          • 26
                          #1 Servo
                          #2 ESC
                          Thank you! That's the answer I wanted to know!
