batts
  • pugman2
    • 236
    batts
    how are the dtx 3600 are they any good
  • H&MWill
    • 623
    We have some dtx 3800's we have used in the SV for a while now and they have worked perfectly.
    Many issues!!!
    • SJFE
      • 4735
      I havent hers anything that bad about the DX's yet. What kind of numbers are they getting?
      • pugman2
        • 236
        do they last pretty good i dont know much about batts . i have heard not to buy ib 4200s cause they have a hi falure rate . i want to get something that will last and get decent runtimes
        • H&MWill
          • 623
          With 3800's we are getting about 8-9 minutes with an Octura x645 prop.
          Many issues!!!
          • pugman2
            • 236
            batterys
            how are the dtx3800 compaired to the ib3600s
            • pugman2
              • 236
              i ended up getting ib3600 s from battle packs im sure they will be good packs
              • ice329
                • 792
                Good move. Cant wait to hear what you think after you run them.
                • Piranha2
                  • 320
                  do you guys recommend 6 or 7 cell packs for the SV? ... and no I won't ask which prop......too many choices/ factors.
                  • H&MWill
                    • 623
                    6 if you are still using the bec. 12 cells is all it is supposed to be able to handle unless you disconnect it. You can then run 14 cells safely.
                    Many issues!!!
                    • Piranha2
                      • 320
                      Thanks for the info H&M
                      • H&MWill
                        • 623
                        No problem.
                        Many issues!!!
                        • wildturkey
                          • 1
                          I have been using the BEC while running 14 cells for quite a while now and haven't had any problems. Any particular reason why I shouldn't do this? I have heard this several times, but never heard any reasons to support it. I am using a Spektrum radio.
