Hi Guys- I'm newer to the sport. I have done some searching haven't found any specific help to stop water from coming in the shaft where the prop meets the blue anodized shaft. I'm pretty sure that's where it's comin in since I have the hatch taped up (learned that lesson the hard way) and fixed the leak on the adjustable fin. There is so much water comin in that shaft that it makes my boat behave badly. Also, where specifically do I "lube the shaft"? near the motor, directly on the "flex" part or?? and what kind of lube do I use? something i can get at home depot, or will the hobby store carry it?
A lot of water coming in, need advice
Tags: None
You didn't describe what kind of driveshaft system you have so it's hard to offer much advice.
One bit that I may add is to fit a piece of silicone (fuel) tubing over the stuff tube and driveshaft where it enters the hull.
Also drill a small hole at the lower aft end of the stuff tube to act as a drain hole. Then you can tape over it w/ hatch tape and remove to drain water at the end of the day, or leave it open so the water can drain out when not in the water.
I use stainless ground 1/8" straight shafts w/ stainless bearings. The driveshaft and bearings are removed and flushed w/ alcohol then re-oiled at the end of every raceday. -
Grease: http://www.offshoreelectrics.com/pro...od=dh-aqub9500
Should be applies along the whole wire drive.
Gotta use the search on the forum! http://forums.offshoreelectrics.com/...ead.php?t=4591
~PeaceLast edited by SweetAccord; 09-17-2008, 06:53 PM.Comment
Hi Guys- I'm newer to the sport. I have done some searching haven't found any specific help to stop water from coming in the shaft where the prop meets the blue anodized shaft. I'm pretty sure that's where it's comin in since I have the hatch taped up (learned that lesson the hard way) and fixed the leak on the adjustable fin. There is so much water comin in that shaft that it makes my boat behave badly. Also, where specifically do I "lube the shaft"? near the motor, directly on the "flex" part or?? and what kind of lube do I use? something i can get at home depot, or will the hobby store carry it?Comment
if you have not removed your hardware and put it back on with silicone you could have leaks there as well do a search on water sealing or leaks (I had a nice thread with a lot of info)The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.Comment
the stock jacket is very bad,, i was getting a lot of water as well... it was so bad i was looking for a crack in the hull....i bathtub tested it..was fine...i have a transom water pu hooked up a hose adapter i made for my gasser,,, i was amazed at how much water was comming from the stock jacket..i also got the OSE jacket.. nice and dry now..Comment
