Prop Finishing Advice
  • SweetAccord
    Speed Passion
    • Oct 2007
    • 1302
    ugh* forget it:
    http://forums.offshoreelectrics.com/...ighlight=props
    • SweetAccord
      Speed Passion
      • Oct 2007
      • 1302
      Originally posted by egneg
      I use a air micro die grinder #47869 from Harbor Freight - adjustable from 0 to 56,000 rpm and mibro #6 high gloss compound from Northern Tools. IMHO better than a dremel but a 10 gal or better air compressor is required.
      Got it today, tried on one prop, and the results are I'm sold, Mikey likes it!
      • Jon K
        • Jul 2008
        • 35
        I machined a spike for... my car ... don't ask.... out of 6061 aluminum. I was going to throw it in my vibratory tumbler but figured it'd round all the corners. So, I used a polishing pad on my dremel at like 8 speed and used Mothers Aluminum Polish. I then used this to polish the part (carefully) straight from being machined - no intermediate grits of sanding or anything. Basically, right off the lathe and onto my desk to be polished!
        Here are the pics
        Before polish:
        Post polish:
        This polish has worked well on copper previously - so give it a shot! Its a small ~2.75" tub from Pep Boys.
        • egneg
          • 4670
          I liked it much better as well - glad I could help.
          IMPBA 20481S D-12
          • SweetAccord
            Speed Passion
            • Oct 2007
            • 1302
            The good thing is that I can balance the props much faster now. I can fine balance with a file, get really close and closer and when it's just right with the files, I can buff the file marks right off. The great part is that you don't need a high speed tool to do it either! Using a dremel that is 5,000-35,000 and not even running it full speed gets the job done easily with mirror results.
            Thanks again for great recommendation egneg!
            • SweetAccord
              Speed Passion
              • Oct 2007
              • 1302
              So, I'm curious. Does or has anyone here polish the back side of the prop and have noticed any top end speed increase? I read somewhere that it was done on a prop and all else was the same and the gain was 1-2 mph more.
