This is a little late hoping for some assistance - I'm about to install my SV with ammo 2300 - Xpower 100amp - Running 20 Cell 11.1V 5400mAh 3S LiPo - - - Props I currently have are cf40, cf45, cf48, x440, x440/3, Grim Racer L42 x 66 Lifter.... will any of these look after that esc ???
8xl xpower 100 prop?
Not sure what this means? "Running 20 Cell 11.1V 5400mAh 3S LiPo ", can you elaborate?Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
That will most likely need way more esc than the x-po 100.
I would run 4s. 6s with the 2300 is asking for problems.Steven Vaccaro
Here is a note about the expower 100 amp...http://forums.offshoreelectrics.com/...ead.php?t=4403Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....Comment
I am running an 8XL in a 33" mono w/x445 prop and pullng ~ 120 amps per my eagletree logger
HTH
GhostComment
Yes..those were peak amp readings .I am running the hi-model 200 amp that Steven here has rated at 125 amps max () so I imagine any true 120+ amp controller would do fine.My cheapy hi-model comes out at about 140 deg and motor is about the same after running the boat fairly hard.
I will say that although a 120 amp Hydra would probably be fine I like to see a little redundancy in power systems and would suggest something just a little larger if available.
HTH
GhostComment
So i should scrape the X-power 100amp. and go with everyone's favorite CC Hyrda 120 or how about HexTronik PRO 120A BESC $56?????Comment
GhostComment
esc
I decided to run the hi model 200 from ose instead of the x power in my sv with the 8 xl from the response in this forum. I used the hi model 200 last weekend and it worked great. Of course you can't go wrong with the cc 120 . I haven't heard about the hextronic esc in boats yet but if you go that route let us know how it works .Good luck which ever way you go.SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieserComment
Being that the sv27 is a smaller boat, I think the Xpower should be adequate. The hex is a good ESC. Just waterproof and cool it. You may have to use a pistix depending on your radio. They do cog with 2 pole motors, but that is at low rpm's and when first starting. Running a brushless ESC at partial throttle in a boat is not recommended as they tend to heat up. I've used the hex and the only problem I had was programming thru the USB port let the smoke out. So my second one, I just programmed the LVC and it works great.Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
Is the issue the Ammo 2300 is too much motor for + Xpower 100 or is (6s 11.4 5400Mah) to much power/ battery for Xpower - I don't want anything to do bang that s the last thing on my mineComment
6S is probably too much for the xpower. It can only use 5S. The Ammo should work with the xpower ESC.
Specs for the Ammo 2300 are:
SPECS:
Motor Diameter: 1.42" (36mm)
Motor Length: 1.97" (50mm)
Shaft Diameter: 0.197" (5mm)
Shaft Length: 0.591" (15mm)
Kv Rating: 2300 rpm/volt
Weight: 8.3oz / 235gr
Input Voltage: 14.8-18.5V
Max. Constant Current: 60A
Max. Surge Current: 100A
No Load Current: 2.0AGovernment Moto:
Remember, Ammo motors are 4 or 6 pole...(read their site) but Fiego are 2...hope I am remembering correctly.
This make a big difference in amp draw.Comment
