8XL with stock ESC
  • ozboater
    • May 2007
    • 415
    8XL with stock ESC
    hello gents
    seems my motor needs to be replaced... i ve noticed a few people run an 8XL with hydra 120 ESCs... would the 8XL work out with the stock ESC ??? my educated guess says yes since it s about a 2100 kv motor... i can run an ammo (2300kv) with the stock ESC so the 8XL should be ok then ?? sound reasonable ??? please inform the misguided aussie...
    noticable speed increase ?? maybe a couple of mph ??? i d eventually like to upgrade to a better ESC but for now i ll need to stick with the chinese maded aquacraft stuff...
    cheers
  • 62 bugzilla
    • Mar 2008
    • 258
    8xl
    I don't think you can run a 8xl with the stock esc even with a tiny prop. Doby has a 9xl in his with the stock esc and seems like it worked great for him. I'm unsure about the ammo even unless you run a small prop and either way you won't have any headroom which is a good idea. If your sticking to the stock esc for a while I would search for doby's boat with the 9xl as an upgrade. My .02 .
    SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
    • Steven Vaccaro
      • 8723
      The 8xl will out amp a stock sv esc. It may be possible to run a small enough prop to get away with it, but what fun is that.
      • Doby
        KANADA RULES!
        • 7280
        Mine takes a 9XL with no problems at all, going on 2 years in one boat.
        Put a 9XL in it and you WILL notice a major speed increase. It also gives more flexability in props.
        Grand River Marine Modellers
        • properchopper
          rcgoatbuild@snotmail.com
          • 6968
          re :
          I totally cremated a stock SV speed control with an Ammo 2300 on my TS-2. [The OB lower unit does cause a higher current draw however.] Beware !
          • ozboater
            • May 2007
            • 415
            sweet... hey doby, what prop(s) do you use with the 9xl ? that motor is the same size diameter as the standard SV motor yeah ? so my OSE water jacket will fit...
            got a photo of the inside of your SV... sorry if you ve posted this before
            thanks for ya help
            oz
            • showstoppercat
              • May 2007
              • 95
              prop selection
              Don't go pass Octura x642 - x645 sharpen & balanced!! thats what I'm using thanks to forum - Ive also tried and gotten away with on a few occasions GrimRacer L42 x 66 Lifter Prop heart stoppin
              • ozboater
                • May 2007
                • 415
                i have an octura 642 here that i haven t bothered to use... i ve had good luck with the CF45 as well as the x440... maybe i should try out the 642...
                doby, what are you running with the 9xl and stock esc ?
                • Comfortably Numb
                  • Jul 2008
                  • 67
                  8xl or not
                  Now i'm getting worryed, I was told that this was an 8xl motor but I have the stock sv speed control and it all works fine. How do you tell what motor this realy is?
                  Do It in Vinyl !
                  • Ctonez
                    • Jul 2007
                    • 404
                    comfy numb - I don't think it's a problem of it not working (and that's not what the others that have given input have stated either), it's a matter of will it last for more than one run...
                    What I'm reading (and what I've experienced) is the amp load on the stock ESC is near the limit with the 8XL...likely over the limit with even a 642 IME (running an 8XL in a slightly bigger hull). The extra pitch of the 642 is enough to spike your amps over the ESC's limit, especially in a mono.
                    KV is the only way I know to tell Feiago's apart, is it etched on the motor? perhaps on the front cap which is obscured by the motor mount? if not, I'm not sure how to tell without some testing gear.
                    PS - I like the CF mods and the blingy blue locknuts...the stringers are CF too? wanna sell me some? show us some more!
                    cheers,
                    -Corey
                    • ReddyWatts
                      • 1711
                      Average amp calculations for a mono hull using a 8XL motor on 4s:
                      X432 - 44 amps
                      X435 - 63 amps
                      X437- 80 amps
                      X637 - 96 amps
                      X440 - 95 amps
                      X640 - 120 amps
                      X642 - 140 amps
                      ReddyWatts fleet photo
                      • Ctonez
                        • Jul 2007
                        • 404
                        There you have it...
                        That's great info Reddy...maybe you should post it in the reliable BL thread too.
                        is that data gotten from FE calc, or your own data gathering?
                        Do you have similar data for other props/motors?
                        • lonewolf
                          • Jul 2007
                          • 658
                          Here ya go this is a real good chart to have....
                          Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
                          • ReddyWatts
                            • 1711
                            I used FeCalc for those numbers. It will give good ballpark figures for 2 pole motor setups. Still a great tool to get an idea about which prop to start testing with. It does not work as well for 4 and 6 pole motors.
                            • kck741
                              • Aug 2007
                              • 265
                              Wow I didnt think an the stock esc could handle the an 8 or a 9XL,just because of the physical mass of the motor pulling more amps
                              S.S.R.C-Southern Style Radio Control
