Is there a low voltage cut off for a stock supervee? or is this something I would have to buy if i want to run lipos?
quick noobie lipo question
Tags: None
Novak makes one. It is called smart stop. If you are runing those in a series then you would need one for 4 cells.Comment
Dimension engineering offers one that takes up to 12s lipos and has a 3v per cell soft cutoff but...I'm not sure if it's compatible with pistol tx as it says "only compatible with 0-100% throttle one way....car version soon " .....dunno...I just ordered one to find out.
HTH
GhostComment
HTH
GhostComment
Ok, so what kind of voltage cutoff and setting is needed if going to run two 2s1p packs (7.4v on each pack)?
Thank you.Comment
HTH
GhostComment
