Battery Supplies for SV27 page
  • sjslhill
    • 1514
    Yes, it per pack, not per cell....LOL
    • SJFE
      • 4735
      Thought so....LOL
      • sjslhill
        • 1514
        Talked to my supplier today and I told him that the packs were doing well. He told me that he is not surprised, the packs are really 4,000 (3,600)mah 12C and 4,400mah (4,000mah) 12C and that he under rated them.
        So, I have not tested one.......but he does not tell me stuff that is not correct.
        • SJFE
          • 4735
          Nice. I only ran them 3 minutes deep on the test. I am going to wire in the lipo shield this eve. This weekend I will set a 2 minute delay on the dpr and time the launch. This way the avarages will be a bit more on the money. First thing I have to do is rewire the esc to a female deans...the make up a parallel and series setups to switch.
          • ice329
            • 792
            Steve that is good to know. If I would have known that I might have went with the 4000 packs. As it is I am happy with how the 3600 LiPos run. I am locked in with alge or I would be running them to get some runs under the belt. When I ran the 3600 LiPos I felt I ran pretty long, I had plenty more to run because when I recharged It only ate up about 50% of the pack capacity. After I run them more I will know but it sure seemed like I got more run time out of them
            PS I got the batterys back thanks.
            • SJFE
              • 4735
              Run down to the local pool shop. Get a 55 gallon drum of clorine..and shock the pond. Problem solved.
              • ice329
                • 792
                If I do that I am sure to get DO crash then the fish will croak. I am getting Tilapia its a fish that eats alge, and I built a areator today and will get it going tomarrow, that should help a lot. If that dont work I can use pond die but then I am getting back into the DO crash because it will kill the alge by not allowing light in. Would be cool driving the boat on a colored pond though. I have plenty of big water here to run but no recovery boat. Wouldnt it be GREAT if TUG that needed a transmitter and reciver and priceed it like 98 bucks.... I would jump on it.......heheh
                • SJFE
                  • 4735
                  #23
                  VAC-U-BOAT my friend. Check out the vac-u-tug. Cheap and easy to build. I think they tow with it. But i'm sure it can be set up as a pusher.
                  • ice329
                    • 792
                    #24
                    Unreal...! I look and there was one, a aquacraft tug. Sometime if you ask you shall recieve.
