Speed setup for SV27
  • chase4556
    • Feb 2009
    • 3
    Hey guys, been out of the RC hobby for a while. I'm now getting a little bored and decided to pull out the supervee's I had back in the day. I have two, and one I am going to leave stock.
    The other one I am looking for a speed setup on. I want to run in the mid 50's if possible. Maybe even 60? What is the best motor/speed control/prop to get me in the ball park so that I can start playing around with tuning the boat and finding the right props. I know a lot of guys have pushed these boats to that speed, but I went through the last 4 pages of posts and couldn't find anything.
    Thanks for any input.
  • chase4556
    • Feb 2009
    • 3
    I have been seeing people talk about the leopard motors. So I have been eyeballing the 4074 and 4082 motors. Just don't know which one to get, and in what KV. Bigger is always better, right?(4082)
    • Make-a-Wake
      FE Rules!
      • 5554
      The one 'problem' with the SV hull is that its fairly narrow which doesnt allow you to spin a huge diameter prop...........you need pitch.
      With all the new 4 pole motors coming out i'd suggest one of those...............more efficient and more torque.
      Here are a few, i own several of these and find them to be very good................especially at half the price of a Leopard of the same size.
      These are all 4 poles as the "B" indicates
      http://www.hobbyking.com/hobbyking/s..._Inrunner.html
      The two 3665's should handle an x640-642
      The 3674 could probably spin an x645...............
      These should get you up near or into the 50's
      • chase4556
        • Feb 2009
        • 3
        Okay awesome. I was planning on getting my batteries from Hobbyking as I used to get all my flight packs from them and had great luck with the quality of the packs. I will decide which one I want and will probably go with one of those.
        • blackcreeksv1
          • 10
          fast supervee
          i currently run a ammo 3656 2600kv, turnigy 180a esc, two 2s 6500mah max amp batts, and a 2 and 3 blade grim racer props! very fast and quite stable too after a precise set up
            • 9479
            I did not think of that one!
            I have one setup with a UL-1 motor and esc, that I did some work to the bottom of the hull..
            maybe a x642 would whoop things up !!
