Grim's setup
  • Diegoboy
    • Mar 2007
    • 7245
    Hey Dirty!
    Glad to see you here! Welcome.
    Thanks for contributing your wisdom!
    • Diegoboy
      • Mar 2007
      • 7245
      I can get some of those motors if you guys like. But the rating for the amps on that motor is 60amps continuous. That's more than the 45amp esc rating.
      Please do.
      • dirtysouth31
        • 514
        i was a member before but since the change i couldnt log on,so i just re-registered.
        • dirtysouth31
          • 514
          and still a member and this place has changed into a bunch of whiners and nuthuggers
          • Steven Vaccaro
            • 8724
            Well then its simple, if you dont like it leave. Let me know if you need any help
            Steven Vaccaro
            • Jeff Wohlt
              • Jan 2008
              • 2716
              A buddy of mine run the 2300 KV ammo with stock AQ ESC and a M440 prop. It ran fastest with that one....we tried a bit larger and it ran hot and not as fast. It needs to spin. This was on a BJ cat so a little different. Mono should be able to take a little more prop.
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • wizard122
                • 483
                This is my best run so far
                I'v posted all my setups at my new sv check them out. This was my last post.
                she ran 52.7 with Ammo 2300
                http://forums.offshoreelectrics.com/...8&postcount=76
                2 SV 27's and Vac-U-Pickle UL-1 Power
