sv27 hull crack
  • dannybj26
    Going fast on the 836
    • Sep 2011
    • 306
    sv27 hull crack
    i recently bought a sv 27 on ebay for $130 and it had one minor spider crack in the gelcoat and after running for 2 days= 5 runs=about 7 min each i got home today and i noticed that ther was about 3 good sized cracks and 1 all the way through the glass and the gelcoat. I DID NOT hit anything where i ran is about 5 ft deep all around and my batts were secure. i dont know is this has happend to anyone exept me but it just ruined the 3 coats of wax/ploish on top and bottom and the good sturdy looks of it
    losi scte full carbon,Hpi baja 5te,Hb tcxx
    Enforcer gator full mod 30cc
    Rico 31
  • roadrashracing
    • 1462
    If it is on the seam, its a normal thing with these boats, from what I've been told.
    • Duster19
      • Sep 2011
      • 64
      Jan at Kintec Racing suggest applying at least 2 layers of Fiberglass Strips (2" wide- Medium weight. Great for adding strength to seams or surfaces). At the same time I went ahead and applied some epoxy to all the wood and transom area in my SV. It's a well known issue with the SV and since I'm hoping to push mine, I figured the extra support would be a wise choice.
      Hope this helps,
      Dave
      • dannybj26
        • Sep 2011
        • 306
        roadrash theres 3 one on the bottom,side,otherside
        Rico 31
        • dannybj26
          • Sep 2011
          • 306
          Duster there's only on that is all the way through
          Rico 31
          • siberianhusky
            • Dec 2009
            • 2187
            The two on the sides are where the sides and bottom parts of the hull are joined probably, this is where you need to run a strip of fiberglass the length of the boat on both sides. They also crack along the top of the transom, not sure what to say about the bottom crack thats not normal, is it where the wood rails inside the boat would be? If so the rails could have come loose and allowing it to flex.
            Which one is all the way through? Minor gel coat cracks are normal on hulls that have a very thin layup. A lot of people add a layer of carbon fiber cloth to the inside bottom of the hull as reinforcement.
            • dannybj26
              • Sep 2011
              • 306
              The one on the lower right side is all the way through them the one on the bottom in in front of the motor but not all the way through
              Rico 31
              • makin' waves
                • Jun 2011
                • 92
                you'll just have to reinforce the inside (where the cracks are) with some fibreglass strips and some z-poxy finishing resin.
                The outside can be lightly sanded and then re-sprayed if you wanted to make it like new again. There are some posts on this forum
                that shows some crack/damage repairs
                Tone
                • dannybj26
                  • Sep 2011
                  • 306
                  but dosnt the supervee have gelcoat ? and i want to keep the factory orange
                  Rico 31
                  • makin' waves
                    • Jun 2011
                    • 92
                    yes it does have a gelcoat, you can get touchup paint from Jan at Kintecracing.com
                    Tone
                    • dannybj26
                      • Sep 2011
                      • 306
                      is it identical to the original factory orange color
                      Rico 31
                      • makin' waves
                        • Jun 2011
                        • 92
                        don't know mate, think they're a close enough match,
                        I resprayed mine silver, have a look on the kintec website....
                        Tone
                        • dannybj26
                          • Sep 2011
                          • 306
                          Ok and just to ask have you modded ur supervee ?
                          Rico 31
                          • makin' waves
                            • Jun 2011
                            • 92
                            yeah mate,
                            just the usual...
                            Upgraded trim tabs,
                            bigger prop, Grim 42x55
                            upgraded flexshaft and collet
                            ammo 2300 motor,
                            seaking 60amp esc,
                            transom water intake (I use 2 water intakes 1 on ESC and 1 on motor)
                            replaced all water tubing for bigger gauge and bigger exit ports one on either side,
                            Removed all radio box (upgraded to carbon fibre servo platform/holder)
                            tatic 2.4ghz controller and reciever,
                            And resprayed red and silver!
                            Tone
                            • dannybj26
                              • Sep 2011
                              • 306
                              is your boat watertight and if it was not how did you fix it also how did you paint it
                              Rico 31
