Having problems with my SV27, IT WON’T GO!!!
Background:
Boat/charger & 3600 mah batteries were purchased used.
ESC makes two sounds a beep (longer duration) and a bip (short duration).
When I say “continuous beeps,” the sound is at about 1 second intervals.
I am using 6 cell battery packs.
First go round, stock Aquacraft SV27 radio…
One batt pack is already plugged in,
Turn the transmitter on,
Plug in other battery pack
As soon as the second battery is plugged in the servo turns hard, counter clockwise (if the bow is 12 o'clock) to turn the boat to the left. There is a low, slow, grinding sound, I think coming from the servo, noise continues until I unplug a battery pack.
There is some response when I try turning the rudder, servo tries to move, more in the same direction but seems “maxed out.” It will not turn clockwise
Also no movement on the prop when I try W.O.T. No beeps, or bips, nothing from the ESC either.
Swap radios and receiver, put in a Futaba T2PH
3600 mah batt’s,
Turn transmitter on,
Continuous “beeps”
Pull trigger to W.O.T.
Continuous “bips”
Let go of trigger,
Continuous “beeps”
Unhook batteries and put them on the charger. They are only charged to about 5.5v. Three days ago they were fully charged.
Switch batteries,
These are 6 cell 4200 mah, charger tells me they are charged to about 8.3v.
Continuous “beeps”
Continuous “beeps”
Let go of trigger,
Continuous “beeps”
One last try (after topping off the charge) with the 3600 mah batt’s,
Batteries are charged to precisely 7.2 volts (okay, one was charged to 7.184v the other to 7.865v
Plug in first battery pack,
Continuous “beeps”
Pull trigger to W.O.T., no change.
Turn transmitter off. About two minutes later the ESC beeps, turn Tx back on, pull to W.O.T. and get another “beep” let go of trigger and… nothing.
Never any movement from prop or rudder after Futaba radio is in place. This is what I would expect if it has not armed, but shouldn’t I get movement on the rudder?
The instruction manual (yes, I broke down and actually read it) does not have any “trouble shooting” help.
Tried the servo rev. sw., no change (just continuous “beeps”).
Tried the other Rev.Sw., get a single “bip” then nothing.
I put the Aquacraft SV27 radio in another boat and it works as it is supposed to – throttle/ rudder O.K.
Swap radios and receiver; put the SV27 radio back in the SV. With two channels and two positions on the servo reversing there are 4 possible combinations of settings. I try all 4 and the boat does absolutely nothing. No beeps, no arming of the ESC, no movement on the rudder.
I will be in and out for the next couple of days – so if you guys suggest something and I don’t respond right away, that’s why.
Chop
Background:
3600 mah batt’s,
Continuous “beeps”
Continuous “bips”
Let go of trigger,
Continuous “beeps”
Switch batteries,
Continuous “beeps”
Continuous “beeps”
Let go of trigger,
Continuous “beeps”
Continuous “beeps”
Chop
