had some problems today, i got the super vee 27 bolt on trim tab Adjusters from kinetic. lost one of the nuts off of adjuster bolt. also the new water pick up causes the crappy water jacket to spray water all over on the inside. any ideas. what water jacket should i get. every thing was cool. still new to r/c boating.
run today
If you have the new one 27r, this appears to be the correct water jacket to get. http://www.offshoreelectrics.com/pro...=ham-ul1-sv27r -
OK, this is the one then. http://www.offshoreelectrics.com/pro...prod=ose-80035
It's out of stock though...let me look around, you can see that a standard 540xl jacket will work, but you have to watch the length because the SV27 motorsare a bit shorter.Comment
I just place a folded piece of paper towel around the leak of the water jacket, it doesn't stop it leaking but it catches any 'Spray'
and its easy to wipe out and remove after you've finished. It is best to get a replacement jacket tho.
Hope this helps
ToneComment
