sv27 GPS Speeds!!
  • ghostofpf1
    • Jun 2008
    • 392
    #91
    40mph stock set up using 4s 4300 mah zippy lipos. Radared using a cheapy Bushnell unit with the front shroud removed for improved accuracy.
    Ghost
    • Ub Hauled
      • Aug 2007
      • 3031
      #92
      Some batteries (the cheap ones) do not hold the voltage under load... you'd be suprprised of how much they drop... I have not seen his setup or anything but just by him saying that he got a "no namer" cheap off of ebay tells me that the batteries have a good
      chance of being the problem... at least one of the major problems.
      • Mich. Maniac
        Banned
        • 1384
        #93
        Instead of editing my post I just wanted to add that I used a Watts Up meter and measured spikes at its max plus. Last max reading was 100.72 Amps. Is or has anyone been able to log their amp draw using 8xl and k45mm prop?
        • hex-dj
          • May 2008
          • 238
          #94
          Ghostofpf1. I sent an MO today to Optics Planet for the same radargun to measure the true speeds on both my moded SV 27 and moded BJ 26. From what I know the Bushnells are quite accurate. I ve seen guys use them in drag racing tracks.
          • ghostofpf1
            • Jun 2008
            • 392
            #95
            I found that removing the smoked front cover enhanced it's ability to pick things up.
            HTH
            Ghost
            • kssi
              • May 2008
              • 43
              #96
              today with ammo 2300,stock speedo, grim 4255 prop, 43 mph i think it is under prop motor seemed hot but speedo was not that warm.
              DF 22 HYDRO
              • Ctonez
                • Jul 2007
                • 404
                #97
                nope, more likely over-propped and not letting the motor hit peak revs IME. try a 437/3 or x440 2-blade, I think you'll get more speed.
                ...you're using lipos, right?
                • hex-dj
                  • May 2008
                  • 238
                  #98
                  Ctonez is right Kssi. Like he said try the Octura x 437 two or three bladed or a 440 2 blades. Never try a 442 with an AMMO as you may fry the batteries... A grim 42 x 55 is way over propping for a 2 pole AMMO 2300.
                  • Jeepers
                    • May 2007
                    • 1973
                    #99
                    or a y536 prop.
                    • kssi
                      • May 2008
                      • 43
                      #100
                      alright thanks for the help guys
                      DF 22 HYDRO
                      • Mich. Maniac
                        Banned
                        • 1384
                        #101
                        Sweeet! Put another notch in the belt man. Over 40 is kewl anyway you get it! Cant wait to see it.
                        • 62 bugzilla
                          • Mar 2008
                          • 258
                          #102
                          8xl
                          Mich Maniac I'm putting your set up in my sv and hope to have good speed to post here aswell. Can't wait to test.
                          SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
                          • SweetAccord
                            Speed Passion
                            • Oct 2007
                            • 1302
                            #103
                            Not mine, but wow they haul:
                            • TRUNKMUNKY
                              • Sep 2007
                              • 56
                              #104
                              • showstoppercat
                                • May 2007
                                • 95
                                #105
                                Ammo 2300kv
                                X-power 100amp ESC
                                Intellect 2s2p 7.4V 5000Mah
                                X642 sharpen & balanced
                                L&R Turn fins
                                Fortrex101 = 45.5mph (80.5km) will upload video soon
                                and is rock solid on plane at speed
