Can this Happen
  • kck741
    • Aug 2007
    • 265
    Can this Happen
    WHen I went to run my SV today it would not Get on a plane,the bow would sit up high and the stern would dig into the water.Am I running the wrong prop.
    All stock
    3600 nimh pack(duratrax)
    L38*55 prop-its a Lifter prop please explain this to me
    thank you
    Kris
    S.S.R.C-Southern Style Radio Control
  • txboatpilot
    • Oct 2007
    • 1494
    You may be using a prop too small in diameter for the boat/setup... Motor rpm is not high enough to use 38mm prop... You should try 42mm prop or 45mm carbon props work well... Lifting props are mostly used on riggers and hydros....
    Nothing like keeping you lipos warm and your prop wet!!
    • raptor347
      • Jul 2007
      • 1089
      Put either a 42x55 or X442 on it. Sharpened and balanced, both props will pull very well.
      Brian "Snowman" Buaas
      Team Castle Creations
      NAMBA FE Chairman
      • Bill-SOCAL
        • Nov 2007
        • 1404
        I run a 42x55 GrimRacer prop in mine. Works well.
        Don't get me started
        • kck741
          • Aug 2007
          • 265
          Is that a lifter prop
          • Bill-SOCAL
            • Nov 2007
            • 1404
            No, it is a standard prop. I usually do not run lifter props on mono hulls.
            • eric-paul
              Luke Propwalker
              • Jan 2008
              • 34
              just a thought. would the rudder angle cause it to dig in? lower tip of the rudder as fwd as possible, creating a small amount of downward force?
              just a thought
              • Bill-SOCAL
                • Nov 2007
                • 1404
                Take a look at this site. Tune up tips from the guy who designed the boat
                • fastbaltek
                  • Aug 2007
                  • 331
                  cf 45 is the way to go cheap and it works great.
