4S2P Lipo
  • RCprince
    • Jul 2007
    • 1637
    it works great, i have it trimmed nice...ride at about 5 degree bow lift..plus i made those tabs out of softer aluminum alot easier the adjust. it ran 38 on the blackjack's brushless system which the motor kv is 1500...I'm about to put in a 3300 kv and try a x632 and a x432 and see what gives with 3's to 4's 4500's
    • Avanti
      • Nov 2007
      • 1280
      RCprince what prop were you running on that ep1
      • RCprince
        • Jul 2007
        • 1637
        I was running the SV stock Prop, now I'm running a x632
        • RiverRat
          • Sep 2007
          • 96
          SV waterpickup
          Avanti if your going to add a water pickup let me know.
          No need to drill holes this is a bolt on for the sv.
          Ill send you a set since you gave a freebee bag away.
          • Bill-SOCAL
            • Nov 2007
            • 1406
            Has anyone actually determined that the stock system is inadequate?? I was running my SV27 today and there was a nice stream of water coming out and at the end of a 6 minute full throttle run the end bell on the motor was 115 degrees.
            I have the OSE cooling jacket.
            Don't get me started
            • Avanti
              • Nov 2007
              • 1280
              no but I will let you know if the temps go down with the new set up after I get it installed.
              the stock set up is just over a trickle out the side of the boat. I want to move the outlet to the back and whould like a solid stream.
              • mike martin
                • Oct 2007
                • 273
                I think the stock cooling is fine I have one of the first s.v. out and run it almost every weekend its all original I use a single 4s set up I cut a piece of 3/32 ply the same width as the batttery and glassed it 1" in front of the motor I run the strut netral with no tab the boat is fast and handles well I race against 25 outher s.v. and just finished 1st in our six month points series with this set up outher boats were running 2p set ups and 2s 1p set ups they all seem to work well though
                • Bill-SOCAL
                  • Nov 2007
                  • 1406
                  #23
                  Mine is a solid stream that is clearly visible from a good distance.
                  • Avanti
                    • Nov 2007
                    • 1280
                    #24
                    yeah you can see mine pretty good but I want to test it with more and see if it is worth wild.
                    • RiverRat
                      • Sep 2007
                      • 96
                      #25
                      My motor temps are about 90 w/ the tab setup. Cooler means less wear. I do all fun runs and testing w/ the tab pickup. On race day I move it back to the rudder but I did have to open up the intake hole w/ a teardrop shape dremel.
                      • FE_Chris
                        • Jun 2007
                        • 764
                        #26
                        About that 1 4s1p pack.
                        I raced my Titan 29 for a couple of heats before the end of the season with only one 4s1p lipo pack on the right side of the boat. (port?)
                        The boat did tilt a little in thw water...But it ran good! better than expected! I ran into a pinch....my 2s packs where not charged....But it worked well.
                        So it's do-able! :-)
                        • Dale Koblitz
                          • Nov 2007
                          • 185
                          #27
                          Where did you find the pick-up/trim adjusters? I've never seen those before.
                          • RiverRat
                            • Sep 2007
                            • 96
                            #28
