i bought the kintec trim tabs adjusters. theyre awesome
Cooling
Yeah you can do that, but I recommend installing the transom water pickup. Some people also use both water pickups, transom and rudder, by using a Y-harness. It's overkill for this boat IMO, but always an option!SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y'sComment
They work different. The transom pickup work better. That's why the new sv come with transom pickup and no rudder pickupComment
Are you sure the water isn't just splattering in the wind? Never had any problems running full systems off rudder pickups.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
although I'm not that familiar with the SV, so it just might be coming up out of the water. In that case, it makes sense.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
I'm also starting to think that it might just be the fact that the boat is coming out of the water at high speeds. It shouldn't be a problem, since it is getting water on the turns and at a lower speed.
I would go with the trim tab water pick-up combo, you get two great upgrades that way.SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y'sComment
