Just finished setting this up in my sv27 and programming it using the pistol. It took a little while to interpret the less than ideal instructions posted online at HK.
I had initially left all of the settings at factory default but have since questioned leaving the factory default lvc.
It is set to 6.0 volts which I am assuming is based on a single 2s lipo.
Since I am running 2, 2s packs in series it seems to me that the 6 volt cut off would be far too low for the combined packs and I would end up over dischargng them since their combined nominal voltage would be 14.8 volts. I'd probably select a 12 volt cut off for the packs since a 6 volt cutoff would pretty much destroy them.
Anyone familiar enough with setting up these ESC's to comment? I want to make sure I have it right before I run it this weekend.
Thanks for reading this.
It is set to 6.0 volts which I am assuming is based on a single 2s lipo. Since I am running 2, 2s packs in series it seems to me that the 6 volt cut off would be far too low for the combined packs and I would end up over dischargng them since their combined nominal voltage would be 14.8 volts. I'd probably select a 12 volt cut off for the packs since a 6 volt cutoff would pretty much destroy them.
