Which motor to upgrade to?
  • domp444
    • Jul 2009
    • 846
    After thinking I had a leak in my boat, I tested out the water cooling and noticed there was a leak right were the motor is. So now I have to get a new water jacket, but I was thinking maybe I should upgrade my motor at the same time and get a new jacket for that.
    So, I'll be running two 2s 5000mah 25-50C LiPos (the new Turnigy nano-tech ones), and a 40/55 prop. I know, I WILL get the 42/55 prop because it's awesome. Just sticking to this one for now. I have the stock ESC on there, stock water pickup, and upgraded trim tabs.
    Let me know! Thanks :)
    SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
  • Elkenamino
    • 20
    My stock silicone water jacket leaked once, I took it appart to look for a crack or tear and found the water tubes had just too much side tension on it. I repositioned the hoses to a more relaxed position and no more leaks! Check that out.
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1679
      Just get a good aluminum water jacket and use the stock motor. It has more than enough power for that hull. I have run numerous motors in there and the stock one was the one that I had the most fun with.
      • onegreenray
        • Jun 2010
        • 213
        how do you feel about the ammo 36-50 2300kv?
        • domp444
          • Jul 2009
          • 846
          Yup, that's probably what I'm gonna do. Thanks!
          I think I'm just going to stick with my stock motor for now. The season's almost over and then it'll just be sitting around. Next year will bring in more upgrades! Unless the motor fries like it did to some other people on here.
          I blew through the cooling tubing yesterday after my run, and there was water coming out of the silicone jacket on the motor. It's also a great excuse to get a better cooling jacket!
          • onegreenray
            • Jun 2010
            • 213
            i ended up replacing the cooling jacket once i added the transom water pick up. it was to much water pressure for the silicon water jacket. also when i opened up the hole and drilled it through the rudder it to was to much water pressure. the metal water jacket can handle the pressure.
            • dana
              Banned
              • Mar 2010
              • 3573
              i use proboat cooling jacket on mine
              • domp444
                • Jul 2009
                • 846
                I am going to order the one from Kintec, along with an upgrade shaft since mine bent after a crash a while ago. I just realized this the other day, haha. I knew there were something wrong with it.
