Hi
Firstly, wow does this thing shift....
...frightening!!
Trouble is, I can't get it to stay on the water..!
3 times out resulting in a flip every time, either during acceleration out of a corner, or full throttle down the straight, and when the pond roughs up with wakes it becomes really twitchy.
Does anyone know the ideal balance point to keep this baby on the water?
Everything is set neutral and batts are shifted slightly forwards to compensate slightly less weight than nimh. Setup I'm running is:
M445 prop
2 x Maxamp 6.0Ah lipos (almost same weight at nimh - and shifted forwards) each lipo having an FMA low voltage cut off module
Transom mounted water pick up
I've ordered OSE adjustable trim tabs and 2nd turn fin (although turning is not an issue).
How can I settle this boat down and actually get some decent run time in?!!
Thanks in advance.
Rob
UK
M445 prop
Thanks in advance.
Rob
UK
