A quick ?
  • Brushless01
    • Apr 2010
    • 487
    A quick ?
    With this kit http://www.offshoreelectrics.com/pro...svcable&cat=52 do i have to use the teflon linear also ??
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • wizard122
    • 483
    Yes you should.
    2 SV 27's and Vac-U-Pickle UL-1 Power
    • Brushless01
      • Apr 2010
      • 487
      How do I get it in there ???
      • Brushless01
        • Apr 2010
        • 487
        Does it go inside the brass
        • m4a1usr
          Fast Electric Addict
          • 2032
          It slides in the brass tubing. The stock SV27 seems to come with a 2 piece section of liner. Not sure why, but it is commonly found as such. Its easier to insert with the stinger off the hull. But you can get it in from the motor side too.
          John
          Change is the one Constant
          • wizard122
            • 483
            Yes remove the motor and the strut bushing then push new Teflon liner into tube and cut to length and your done runs much smoother.
            • Brushless01
              • Apr 2010
              • 487
              Ok thanks
              • archuraas769
                • Jun 2010
                • 53
                i wouldnt use the liner cause mine melted to my flex shaft , but thats just me i gues
                • wizard122
                  • 483
                  How did it melt it? It's teflon and should be lubed any way. You may have something not lined up right. The one in my boat is a year old and looks new.
