Videos of my SV using 2S LiPos vs. 3S Lipos
  • ms71171
    • 119
    SV27
    Mods: Port side turn fin, dual water pickups, Octura X642 balanced/polished, stock motor and ESC
    First Video running Turnigy 20C 2S 5000Mah Lipos - Few really cool flips and barrel rolls.
    Second Video running 20C 3S 2300Mah Lipos - Think I need some weight in the front...
    32" Toysport Triton, stepped hull, no flood chamber, 1515 1.5y NEU 1500kv motor, 180a Turnigy SC - running 6S, Aquacraft SV27 - currently running UL1 motor on 4S. Boat has seen 59mph running Feigao 11XL on 6S, 17" Velocity Minicat
  • Dale Koblitz
    • Nov 2007
    • 185
    So are you running it in parallel or serial? 6s will certainly fry the stock esc before to long won't it?
    • ms71171
      • 119
      I did not change the stock wiring so I'm running in parallel as 6s. Guess I'll by a new ESC once this one fries : )
      • Diesel6401
        Memento Vivere
        • 4203
        In the first post it says your running 2 3s lipos, but in the last post you say parallel 6s. I'm so are you running 2 3s packs or 2 6s packs?
        2 3s in series = 6s
        2 3s in parallel = 3s
        - Diesel's Youtube
        - Diesel's Fleet
        • calcagno45
          • Mar 2008
          • 1006
          Definitely think thats 2 3s packs in a series for 6s total...
          • Diesel6401
            Memento Vivere
            • 4203
            That's what I'm thinking. He must have missed labeled it.
            - Diesel's Youtube
            - Diesel's Fleet
            • ms71171
              • 119
              2 3s in series = 6s
              I'm running everyday 2 2S packs using the stock wiring config which I thought was in parallel, but it's in series It seems.
              I tried running 2 3S packs from my buddies boat and that's the second vid.
              I'll do some research again this weekend to learn more about the various combinations of props/batteries/esc etc. I've just had too much fun playing with it so far to really learn enough as I should about the wiring.
              • Diesel6401
                Memento Vivere
                • 4203
                Yea make sure you do some serious reading man, wiring something up wrong good be very bad especially when dealing with lipos. Also pm sent
                - Diesel's Youtube
                - Diesel's Fleet
                • Dale Koblitz
                  • Nov 2007
                  • 185
                  I run 2-2s in series and it's as fast if not faster then your second vid. I use 6mm gold connectors but if u go to the second diagram and choose 3 series you can get the general idea. http://scriptasylum.com/rc_speed/_lipo.html I think if you run 2-3s in series you'll fry your esc very fast!
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    Running 5s you WILL fry your set-up! The question is how long will it take...
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • ms71171
                      • 119
                      Well, it finally fried my stock esc. I ran my 2 2s last night and this morning the motor just barely turns and makes a electronic chattering sound.
                      I ran the 6s 2 3s lipos once last week in a few bursts so that did it.
                      Oh well, I have a new Seeking 120 on the way and that new Feigao motor from Diesel.
                        • 9479
                        The stock motor and esc will take 5s for sure
                        I run my SV on 5s and run low 50's
