i wana pick up some green cooling tubes but idk were, or could i just use gas lines from rc gas cars?
cooling tubes
Tags: None
That's what I did after my cat chewed through mine the first night I had the boat.32" Toysport Triton, stepped hull, no flood chamber, 1515 1.5y NEU 1500kv motor, 180a Turnigy SC - running 6S, Aquacraft SV27 - currently running UL1 motor on 4S. Boat has seen 59mph
running Feigao 11XL on 6S, 17" Velocity Minicat -
Yes just try to get the largest you can find. You need all the flow you can get.
Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
this is what i use.
or this
2 SV 27's and Vac-U-Pickle UL-1 Power
Sure do
Yes I use them in My SV
damn ur runin 10000 mAp im only runin half of that, is that mottor stock? and are those UL-1 turn finsComment
Hes running 5000 mahPrince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.Comment
Series curcuit mah stays the same, voltage doubles. Parallel would be opposite. No those are not ul1 turn fins. Ul 1 only has 1, those are kintecracing.com carbon fiber fins (very nice i might add). http://www.kintecracing.com/Turn_Fins.html yea stock motor in that pic with upgraded water cooler.Comment
