Re SV 27 Motor and Propshaft
  • Ctonez
    • Jul 2007
    • 404
    The fast time may have been recorded during your flip or other time in the air...I've had some crazy readings caused by the boat catching big air or flipping wildly.
    If the boat is travelling through the air at 47, but the GPS/boat is doing a forward 360 whilst doing 47, then the GPS is going faster than 47 at some point.
    • m4a1usr
      Fast Electric Addict
      • 2038
      Most if not all small handheld GPS units use positions in its speed calculations. Based upon a series of trackpoints. Each trackpoint is basicly a recorded longitude and latitude. That gives location and then depending on each successive measurement (as long as the GPS stays glued to the particular satelites) you get speed based on travel time from one location to the next.
      Each trackpoint has some error in the calculation and its a variable amount between each trackpoint. I.E. its not linear. That means the errors are cumulative. Thats why trackpoint GPS is not accurate. Never will be. GPS units using doppler shift have greater accuracy in determining speed.
      John
      Change is the one Constant
      • wizard122
        • 483
        Ammo 2300
        If you want to go that fast stop buying stock motor and get a Ammo 2300 or a UL-1 motor I run with 4S2P 5000 40c I can easly get 46-52 mph it all depends on prop and weather. And all my temps around 120
        2 SV 27's and Vac-U-Pickle UL-1 Power
        • ggcrna
          • Apr 2010
          • 37
          Hey Brushless 55:
          Where do you mount that Garmin GPS in your hull?
          I have the same wrist mounted running gps & have tried mounting inside the hull @ the stern port side. But after a run, I get these super slow #'s like 5.6mph. I think the GPS is unable to "see" the satellites because it is covered by the hatch. Do you have any thoughts?
          • wizard122
            • 483
            Gps location
            Mount it with velcro just foward of the motor
            • ggcrna
              • Apr 2010
              • 37
              mounting
              Thank you.
                • 9488
                stop buying stock motors?
                the motor came with the SV when I bought it...
                I'm getting 47mph + on 5s with the stock motor
                  • 9488
                  #23
                  Originally posted by [email protected]
                  Hey Brushless 55:
                  if you look at the first picture, you will see where it sits..
                  I cut a pool noodle in half to keep the batteries forward, that gave me a perfect spot to put my gps
                    • 9488
                    #24
                    That was my first thought, but it was going much faster than the second run before it launched..
                    and it sounded like a ticked off SV
                      • 9488
                      #25
                      What about this motor for one of my SV's?
                      and your thoughts!
                      • forescott
                        Hopelessly Addicted to RC
                        • 2686
                        #26
                        I would like to see that outrunner in the sv. Tons of torque! And low amps!
                          • 9488
                          #27
                          being this motor has possibly more power, could it be even with the same KV this could be a faster motor?
                          • forescott
                            • 2686
                            #28
                            I know it would probably turn a bigger prop easier than the stock motor, with less heat.
                            • wizard122
                              • 483
                              #29
                              That looks like a hot motor hope you get one let us all know how you make out?
                                • 9488
                                #30
                                I'm waiting on some 4s packs to be back in stock, and I think I will try one of those motors with the order..
                                I did find an extra SV motor and put that in last night!
                                and the stock one was slightly demaged..
