I just ran my new SV27 brushless today for the first time on a backyard pond. During the initial run, I checked first to see if water was exiting through the outlet on the port side......no luck.
We pulled the boat in, and removed the brass fitting at the rudder top.
We found it clogged with sealer. We cleaned the fitting, and reinstalled it. I also blew air through the flexible water tube that attaches to this fitting, and felt air come out at the water outlet on the boat's port side. I also blew air into the brass fitting (after it was reinstalled) and verified that air came out the water pickup port low on the rudder.
So....it seems that I verified a complete circuit for water flow. We put the boat back in the water, and ran it again.
Still no visible water stream at the water outlet port.
I ran a two complete sets of batteries, and checked the motor temps. It was warm to touch....never hot. I never saw any water coming out of the outlet.
What does a normal water exit stream look like? The only mod I made to the cooling system was the black OSE anodized cooling jacket.
Any other ideas on what to do to get cooling water flowing? Does the system need to be primed somehow? Is it possible that I need to enlarge the diameter of the water pickup hole on the rudder?
Thanks for any advice. The boat has run great so far......wicked fast.
Bruce
Bruce
