Okay........lets get this figured out. ESC works fine with 12 cells but when I switch to 14 cells sometimes it takes off on its own like someone else is controlling it. I've seen on this forum and in the OSE description for this ESC that taking out the RED WIRE from the esc to the receiver and using a separate receiver pack corrects this problem. Well, took it out yesterday with the red wire removed and when using 14 cells the problem was worse than ever. The boat actually slammed into the pond wall and completely punched in the nose of my SV
So what is the story here
does this trick actually work or is it a joke, has anyone else pulled out the red wire and had it work???? Do you have to remove the receiver battery since there is no ON/OFF switch to stop signal interference????
I'm thinking this ESC is junk, maybe the UL-1 esc doesn't have these problems.
Thanks,
Tbone
Thanks,
Tbone
