polarity of radio charging jack
  • ozboater
    • May 2007
    • 415
    hey folks... still loving my sv despite the fact that i m on the stock POS radio system.... i figure i may as well build a decent stack of batteries before upgrading the radio... anyway, i m sick of going through expensive duracell batteries and i ve invested in some GP 2300 AA's for the radio... i was wondering if anyone knows the polarity of the small charging jack on the stock AM radio... it s a small circular jack with a centre pin ??? is it as simple as figuing the polarity of the jack and then rigging up a simple harness with a deans on the end ??? then i guess it d juct be charged on my MRC 977... i ve heard that very low amps is the key... can anyone explain the whole process to a stoked newb ??
    cheers
  • NorthernBoater
    • 811
    Generaly the standard is the center conductor is positive and the outside conductor is negative. Just hook up a voltmeter and that will tell you which is which.
    • ozboater
      • May 2007
      • 415
      thanks northern... anyone got any tips for charging these AAs ?? charge rate etc..
      • hkusp45
        • Jun 2007
        • 299
        1C is always best.
        IE:
        If your cells are 1600 mah then charge at no more the 1.6 amps
        or
        If your cells ar 600 mah charge at no more then .6 amps
        NAMBA #581
        Q mono NAMBA record holder
        'REMEMBER SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO SHOOT THEM'
