LiPo Question
  • bigwaveohs
    • May 2009
    • 535
    LiPo Question
    Am contemplating two 2S1P configurations for SV27:
    4500mAh @30C
    4000mAh @40C
    Any recommendations?
    I let the dogs out...
  • Doby
    KANADA RULES!
    • 7280
    Zippys or Turnigys (5000mah) from Hobby King.....can't go wrong for the price. Have used both extensivly this season with great results.
    Grand River Marine Modellers
    • wizard122
      • 483
      use lease http://www.hobbycity.com/hobbycity/s..._40C_Lipo_Pack
      2 SV 27's and Vac-U-Pickle UL-1 Power
      • Doby
        KANADA RULES!
        • 7280
        "C" rating is what the batteries "Should " be able to deliver to the controller and motor.
        The controller and the motor/prop set up determines how much current is being drawn from the batteries. Use the higest "C" you can find(afford), the controller will be fine.
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          bigwaveohs.
          With both those packs you are sacrificing run time for a higher C rating that the SV doesn't really need. That is unless you have a hotter motor/prop setup than stock.
          Don't forget current draw capability of a pack is a product of the capacity & the C rating.
          Lets see.
          4000mah 40C.... 160A capability but lowest run time $25.00
          4500mah 30C.... 135A capability slightly higher run time. $25.00
          You could try these for more run time @ only a few bucks extra.
          5000mah 30C.... 150A capability & more run time $28.00
          5800mah 25C.... 145A capability @ the most run time $28.00
          The prices are based on Turnigy packs
          Since the SV only draws between 40A- 60A, the higher capacity packs at lower C ratings more than cover the load & give you more 'fun' time between charges.
          I run the 5800mah 4s 25C packs & Himodel 5350mah 25C 2s packs in other boats on bigger motors/props & have great run times & no heat problems.
          Just my thoughts.
          Paul.
