motor getting really hot
  • sv27newb
    • 3
    Is the motor suppose to be very hot after runs. If its very hot, is there anything wrong.
    it seems that I am losing power midway during my runs, is this because the engine is so hot
  • H&MWill
    • 623
    Need more info.
    Batteries?
    Prop?
    How is boat trimmed?
    Any binding in drive line?
    Many issues!!!
    • sv27newb
      • 3
      info
      i am really new to electronics but I will try my best to answer some of your questions
      I am using
      two venom 3600
      I bought a Grimracer three prop- dont know the size, just bought it after destroying my stock one- never got it balance but did sharpen it
      I did check the colling system and it looked fine
      I did notice very littel smoke coming from the reciever are, not much at all but did see
      hope this helps
      My sv feels very slow for some reason compared to others I see.
      • sv27newb
        • 3
        trim
        what does " trim" mean
        also, how do I check if there is any binding on the shaft and prop
        • NitroVal
          • Jun 2009
          • 423
          We need to know the prop size. On the Grim Racer props it will be stamped on the hub of the prop. If you got a prop that is too big, you will overload the motor/esc with ease..
          What size batteries were you using?
          The RTR Nightmare- Electric King of Shaves
          Now with 540s- 62mph
          New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
          • H&MWill
            • 623
            I have tried those batteries in the past and they will not cut it for boat use. They just cant put out the power. Prop should really be balanced and we need to know the size. As far as trim, where do you have trim tabs set at and strut angle? Get 2 new packs af batts and start there.
            Many issues!!!
