Vxl rio ep
  • medina619
    • 63
    Vxl rio ep
    well my new Rio EP has not even arrived yet and I'm ready to upgrade. Im new to the R/C boat world but I'm coming from the R/C car world. I've been lurking around and just reading up on the Rio and other boats. i run brushless and lipos in my Car's and plan to do the same in my RIO.
    my question is has anyone dropped in a Traxxas Velineon system in their RIO? I figured that a VXL would fit nicely in the RIO especially since its water proof. i also intend to upgrade the servo to a water proof traxxas servo.
    do you guys have any recommendations on esc placement or any pointers?
    The Brushless crew!
    Losi Ten SCTE/Team Associated SC10/Axial Exo Terra/Apparition Offshore Brushless
  • hyrulejedi86
    • Aug 2009
    • 494
    I know of it being done and the biggest problem was watercooling the ESC. And the fan doesn't do much as it will only be blowing the warm air in the hull back over the heatsink on the VXL unit.
    Otherwise, The one I saw that had it ran pretty well, on both 2s and 3s.
    • medina619
      • 63
      im even considering using a sidewinder esc, im hoping some one has had some positive results with any of these ESC's
      The Brushless crew!
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7128
        nope. use car ESCs with cars and boat (oh I guess airplane ESCs that are water cooled) for boats. I have ruined a sidewinder in a (what I thought was) mild set up. For boats, that motor is a relative amp hog 3500 KV is high for boats in the upper 20" range. If you do it is a 2S boat. 3S you need to be back at 3000 or less. I have been there and also burnt out a Velineon motor.... no warranty. 2200 KV would be ideal on 4S and a 100amp ESC then it would be just out of control, but a lot of fun. I would recommend reinforcing the hull with carbon fiber or fiber glass.
        "Look good doin' it"
        See the fleet
        • medina619
          • 63
          any BL combo recommendations then?
          The Brushless crew!
          • medina619
            • 63
            are these worth trying?
            The Brushless crew!
            • goobs
              • May 2010
              • 18
              i tried the vxl combo. WAY TOO MUCH POWER!
              i currently have a sidewinder on 2s with the stock motor and have never had any overheating issues. on both sys. im running the 3 blade prop off of the sv27.
              • medina619
                • 63
                so your running the stock brushed motor?what speeds are you getting?
                The Brushless crew!
                • goobs
                  • May 2010
                  • 18
                  Originally posted by medina619
                  so your running the stock brushless motor?what speeds are you getting?
                  no the stock brushed motor that came with the rio.
                  the vxl sys. on 3s i couldnt go over 1/2 throttle w/o it barrel rolling and torque rolling. the speed would be around 40mph im guessing i know about half throttle it was 20+
                  right now on 2s it torque rolls, not to bad though just needa tune it.
                  • medina619
                    • 63
                    what speeds are you getting with your current set up( sidewinder+stock motor)?
                    The Brushless crew!
                    • goobs
                      • May 2010
                      • 18
                      mid to high 20's on 2s
                      im going to do some tuning this weekend. ill post up how it goes.
                      • wakeboardfusion
                        • 462
                        I tried the VXL system in my rio, it pushes it pretty well. I used 2s.
                        • medina619
                          • 63
                          any heat problems?
                          The Brushless crew!
                          • wakeboardfusion
                            • 462
                            Yes, you can only run it for about 5 min before it starts to get really hott.
                            • NUTZZZ
                              • Sep 2009
                              • 3
                              I just ran my rio ep for the 10th time or more with vxl system installed. I drilled holes thrugh heat sink fins and ran alum tubes though holes and connected into existing coil around motor can. Running a 2cell lipo 6000mah smc battery and get about 25 min. runtime at about 25 mph maybe more. I love the ruster tail it shots about 6 ft in the air. Not the most stable of boats but fun. I think I need a larger c rating battery.
