RIO Ep Propeller Shaft Size
  • petricek
    • Jun 2010
    • 17
    I just wonder if RIO Ep uses 3/16 or 1/8 propeller (shaft ). I want to replace stock with octura. Thanks.
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7116
    I'm pretty sure its 1/8" but you can shim with K&S tubing to use 3/16".
    what setup are you running? be careful not to overload your system and burn up battery and/or ESC...
    "Look good doin' it"
    See the fleet
    • petricek
      • Jun 2010
      • 17
      I have for now Traxxas XL-5 with stock motor. I also have Traxxas Stinger 20 turn which I didn't tried yet. I already melted down 12 turn Titan because I run it with stock 42 mm propeller.
      After I will fix all stock boat problems ( motor mount,battery holder and flimsy hull I will go brushless.
