Got my rio ep, and want to go faster
  • forescott
    Hopelessly Addicted to RC
    • 2686
    #31
    Originally posted by traxxas4fun
    so how did you shim it? and did the other prop work better than the king of shaves one
    I cut a piece of bras tubing to fit between the prop and prop shaft(not sure the diameter) but it takes up the play. I like the 535 better. But they perform very similar.
    • forescott
      • 2686
      #32
      The octura prop is a 1/8 inch shaft, but it is more expensive plus you have to balance and sharpen it.
      • forescott
        • 2686
        #33
        Yep, thats the one. And here is the link for the venom prop. Be careful to order the right one because they sell these in counter-rotating as well.http://www.venom-group.com/itemdesc.asp?ic=1983
        • petricek
          • Jun 2010
          • 17
          #34
          That Traxxas Titan 12 turn needs smaller prop for sure. Genraly, less turns = higher rpms. I melted down mine with stock prop.
          • forescott
            • 2686
            #35
            I think I'm gonna stay away from the traxxas 12turn. I've been reading a lot about these motors in the traxxas slash, and they seem to be very short lived. My original 12-turn lasted 2-runs on the stock prop too.
            • Diesel6401
              Memento Vivere
              • 4204
              #36
              Mine is still kicking even though its benched. Ran on the stock prop on a 7 cell ran high teens. Even lasted a few runs in a rescue boat pushing the rig system and a downed boat with the stock prop, matter of fact the video in my signature is on titan 12t rescue. Maybe I got lucky and got one that works... I have read alot about those crappin out though
              - Diesel's Youtube
              - Diesel's Fleet
              • forescott
                • 2686
                #37
                I pushed mine too far with 9.6v nimh. Funny though,I put a 2s lipo in and its fater than the 9.6v nimh. Probably a lot to do with the weight difference though. Hmm.... Maybe I will give the 12-turn another shot. They are pretty cheap!
                • forescott
                  • 2686
                  #38
                  Heres a vid!
                  • Jesse J
                    scale FE racer
                    • Aug 2008
                    • 7116
                    #39
                    nice video! how hot was the motor after the run?
                    "Look good doin' it"
                    See the fleet
                    • forescott
                      • 2686
                      #40
                      I didnt have my temp gun, but It passed the five second finger test!
                      • traxxas4fun
                        • Jun 2010
                        • 15
                        #41
                        so it this the same prop? http://www3.towerhobbies.com/cgi-bin...?&I=LXXSP1&P=7
                        • forescott
                          • 2686
                          #42
                          Nope, the one in the video is the octura y535.
                          • wizard122
                            • 483
                            #43
                            Has any one tried on of these motors Graupner Speed 600 they come in different versions all depends on the voltage you are using check this out.
                            I believe the are 550 can motors and you can use stock cooling coil.
                            2 SV 27's and Vac-U-Pickle UL-1 Power
                            • Jesse J
                              scale FE racer
                              • Aug 2008
                              • 7116
                              #44
                              I am gonna try one with a 2wd slash esc. 2-3S? Should do a'ight.
                              See the fleet
                              • traxxas4fun
                                • Jun 2010
                                • 15
                                #45
                                the slash 2wd esc is rated for 8.4volts.. not 3s
