Rio EP Brushless Setup
    • 9488
    I don't think the 35mm prop will have enough bite on this hull
    36mm would be the very smallest I would go, a 38mm could get some great speeds but a 40mm I think would be better
    • KajunATVer
      • Feb 2010
      • 8
      Thanks for the input guys. Where can I find a 38mm and 40mm prop that fits a 1/8" shaft? The 35 was the only 3 blade I found to fit a 1/8 shaft.
      • Assocracer
        • Jul 2008
        • 46
        I actually had to go to a fairly small diameter prop. I'm running the 1440 Octura plastic prop and my torque roll went away, and i get halfway decent speed with a 2s lipo. I'm running a Tekin RS speedo with a Novak 10.5 motor until my 36-56 motor and 60A speedo come.
        • Assocracer
          • Jul 2008
          • 46
          the 10.5 motor is a 4200Kv motor, and the one i have coming is a 2600Kv, but i plan on running 2 2s lips with that.
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7128
            you can make a shim out of brass tubing.
            have you checked your trim tabs? maybe try taking them off completely and see how she rides.
            "Look good doin' it"
            See the fleet
            • Karfrik
              • Jun 2009
              • 1177
              Here at OSE,click "Home" up in the links.Thats gonna take you to OSE store.Then look for "tips",click and go there.You`ll find there how to make 3/16" shafts prop fit 1/8" shafts using home made bushings like Jesse is suggesting.Very easy to follow instructions and you save money as its easier and cheaper to get props in 3/16 than 1/8.This way you can use them in bigger and smaller boats!!,...hope this helps,...Al
              • goobs
                • May 2010
                • 18
                would this be a good prop?
                Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
                • forescott
                  Hopelessly Addicted to RC
                  • 2686
                  #23
                  That could be a great prop! I'd like to try one.
                  • forescott
                    • 2686
                    #24
                    you would have to space it down to fit the 1/8 inch shaft.
                    • goobs
                      • May 2010
                      • 18
                      #25
                      i've got a spacer ready. i think im going to try it.
                      • forescott
                        • 2686
                        #26
                        Let me know how it works out!
                        • goobs
                          • May 2010
                          • 18
                          #27
                          well i ran this in my rio with a cc sidewinder w/ the stock motor on 2s and i think it gained maybe 3mph, it seemed like it was faster anyways. and got rid of some of the torque twist.
                          also i dont know if its because i cut the scoop out on top of the canopy or because of the prop change but everything was maybe a little warmer than ambient temps outside. and before stuff was getting HOT!
                          overall i like the prop and would recommend it as an upgrade.
                          i will get plenty of test time this week since ill be at garner st. park.
                          after i get back ill try brushless again.
