Chine Walking/ Stability Issue
  • jakevisser10
    • May 2015
    • 100
    I upgraded to a leopard 4074 2200kv and seaking 180 amp esc. Everything else is stock. I have tightened and sharpened the hardware, as well as adding an additional water pickup for the esc. I have rounded the bottom of the rudder to help reduced the lift. At about 3/4 throttle 30-35mph it starts to chine walk pretty bad and is very unstable. I have the turn fins pulled up halfway and angled back slightly. Trim tabs parallel to the keel, except for right inner to counter for torque roll. Strut and rudder are neutral as well. I am running on an m445 prop. I have messed around with the COG a lot and when the batteries are forward it reduces it a lot, but it is still very unstable. Could this have more to do with the weight distribution of electronics inside the hull? ESC is tucked into the rear port side, while the servo and receiver are on the starboard. Should I use weights to try and balance out the sides evenly or play around with the configuration of the electronics? Is it too much weight for the rear of the boat? Im guessing that the port side should be a little bit heavier to help with the torque roll as well? Please give me some feedback as to what you think may help.
    • 7673
    I am going to throw this page out at you http://www.modelpowerboat.com/conten...tude&styleid=4
    At the left side is further help. Read it all, this is my 'go to' basics. Basics first then get crazy with speed bit by bit.
    Shawn
    • jakevisser10
      • May 2015
      • 100
      Alright I read it, but do you think that I should change my configuration up at all?
      • photohoward1
        • 1607
        Where does your boat balance? As you get the nose down it has a tendency to be more stable. It may not be as fast but there is a fine line between stability and speed.
        • jakevisser10
          • May 2015
          • 100
          im trying to find out because i think that my balance is way off which is contributing to the chine walk. At full speed it seems to run almost completely out of the water.
            • 7673
            Take a pencil and set it on a table, take your boat and set it on the pencil(a dowel will do also), move the boat forward and back till you determine where it balances. Then take a tape measure and measure from the transom of boat to where that pencil balanced the boat. This gives you the CG
            • jakevisser10
              • May 2015
              • 100
              Do I do this without batteries?
                • 7673
                All loses up like you are putting it in the water. Hatch on as well
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  Jake.
                  It may just be the camera angle but it looks to me that there might be too much negative angle on your strut. This would be lifting the hull up at the transom, & not leave enough hull in the water. That could be why tit seems to run completely out of the water. A classic cause of chine walk.
                  Try setting the strut parallel with the keel of the hull. Use a straight edge along the keel & over the strut to see the angle.
                  Any chance of a side view shot of the rear of the boat.
                  Again it might be the camera angle, but the rudder seems very short.
                  I wouldn't have one trim tab down at a different angle to the others either. This could also set up the oscillation that turns into chine walk.
                  Cheers.
                  Paul.
                    This has some good info I posted. It fixed this guys problem.
                    http://forums.offshoreelectrics.com/...ght=Chine+walk
                    • jakevisser10
                      • May 2015
                      • 100
                      I think it could definitely be my rudder. It has a lot of slack.!if tightened everything but I don't know how to get the pin out
                        That will do it no doubt. Take the set screw out and push the pin utheough the set screw hole with a pick.
                        • jakevisser10
                          • May 2015
                          • 100
                          The screw set won't come out. It just strips my Allen wrenches
                            You need to get a set of the red Allen wrenches. They are hardened. Made by dynamite.
                            • jakevisser10
                              • May 2015
                              • 100
                              Alright thanks. Do you think I need a new pushpin or could I just loctite the screws in place?
