I just ordered a leopard 4074 2200kv with the 180amp esc. I plan to run this all on 4s with 6mm bullet connectors on everything. I want to get around 50 with good run times (3-5 minutes), while keeping everything at a safe temperature. Which prop would be best for performance and temps? Feel free to suggest any props for this setup!
x642 or M545
Tags: None
I made my water pickup go out the bottom of the rudder. Best thing I to improve the Revolts cooling. Tracked with Eagle Tree so I know it worked. Good luck.Do It Like You Mean It .....or Don't Bother -
They will be very similar................... both good choices for 4s.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I'm going to start with the x642 and if temps are good, then I will move up to the m545
Sent from my iPhone using TapatalkComment
