Crashed boat, need advice please
  • danallen
    • May 2014
    • 55
    Hello guys, the other day my Revolt 30 had a run in with some rocks and I'm not sure what to do.
    I'm debating on attempting to repair the hull (although hesitant to do so due to my lack of experience with fiberglass), or buying another hull and swapping the hardware and electronics from the Revolt into said different hull.
    If you guys think that the hull is not worth repairing, would I be able to just swap over the revolt hardware/electronics to something like the Delta Force Cyber Storm 33 hull?
    Your advice is greatly appreciated, thank you in advance.
    Some pics of the damage:
    DF29 - http://forums.offshoreelectrics.com/...ild&highlight=
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    Look for another revolt hull is my opinion.
    Df33 is a bit large for your motor esc
    • Alexgar
      • Aug 2009
      • 3534
      delta force 29 would run well with your set up you could fix that but it would be alot of work
      • HOTWATER
        • Nov 2008
        • 2323
        Ouch!!! That hull is pretty much mungered!!! If you do not have experience with F/g, I would start looking for anther revolt hull as mentioned in one of the above posts...start a thread in the "wtb" section here on ose...
        Good luck and stay outta the rocks!! ; )
        -Kent
        "Will race for cookies!"
        IMPBA D12
        My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
        • Chilli
          • Jan 2008
          • 3070
          mungered?? Is that a Delaware term. LOL... and shouldnt you be working on the Q Sport??
          I'm with the Aiden and Kent. Find another Revolt hull. Keep and eye out for scratch and dents on Tower's web site..... The the DF 29 could be sweet also.
          Mike Chirillo
          www.capitolrcmodelboats.com
          • HOTWATER
            • Nov 2008
            • 2323
            Lol! I think it's the Cali talking...
            ...Sanding...sanding...sanding and sanding boss...should've bought a phil T. ....lol! J/K!!
            IMPBA D12
            • Alexgar
              • Aug 2009
              • 3534
              df 29 has a more solid layup better for over powering down the road, rtrs are great but thin
              • Chilli
                • Jan 2008
                • 3070
                You would be doing just as much sanding with the PT. No gelcoat on those boats.
                Mike Chirillo
                • HOTWATER
                  • Nov 2008
                  • 2323
                  May just clear it with west systems and run it as is...lol!
                  Sorry about highjacking your thread Dan....; )
                  IMPBA D12
                  • danallen
                    • May 2014
                    • 55
                    Thanks for the advice guys, I'm not sure if I am going to get another revolt hull or try a DF29 build.
                    • T.S.Davis
                      • 6220
                      Delta 29
                      Pursuit mono
                      Insane FE 30
                      If you're up to building you could pick up an ML Boatworks kit. Very sweet runners.
                      Blazer Whiplash 20 is perfect for that power plant too. That requires a little imagination though as they were never intended for FE.
                      If you went with another mono the hardware will swap right over.
                      Noisy person
                      • danallen
                        • May 2014
                        • 55
                        Again, thanks for the advice. I just ordered a DF29 from our host. I'm sure I will have some other questions for you guys once I start my build.
                        • T.S.Davis
                          • 6220
                          You will not be sorry. My son races that boat on spec power.
                          Noisy person
                          • Darin Jordan
                            • 8335
                            Just a note of reference, but Scott Bickford runs a DF 33 on P-LTD power and the thing FLIES! He kept it minimal and light.
                            Darin E. Jordan - Renton, WA
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              what would you have suggested the op got? the 33"?
