Revolt 30 on 5s
  • Scamp73
    • Dec 2011
    • 95
    Revolt 30 on 5s
    Has anyone tried their Revolt on 5s? What changes do you need to make? ESC? Ect?
  • Shovelnoserc
    • Mar 2012
    • 221
    When they first came out a friend and I ran it on 5s ALL Stock, we ended up using Octura 440/3 props for a while. The 1800's and esc's went into a Ms. Geico dual motor conversion which is still running on 5s.
    Then we changed the motors to the 2030kv's and ran 4s
    About 2 weeks ago I ran the 2030kv on 5s with a cnc 45mm prop and a swordfish ESC, It worked great & the temps were normal, I was running next to the guys on 4s with the LEO 2200kv guys.
    Q: Do you know the difference between Men and Boys...?
    A: The price of their toys.
    • Scamp73
      • Dec 2011
      • 95
      When you ran the stock set up on 5s did you make and changes besides the prop? Disconnect the BEC? How was the heat? and how was the change? Speed wise?
      • Cinnabun
        • Jun 2013
        • 433
        Friend of mine runs his revolt on 5s with a seaking 120a and an x445 prop. Mine on 4s with a 3674 2200kv leopard and a m545.
        His is close in speed to mine, but you can tell the difference in torque between the two motors and you can tell the RPM difference between the two.
        • Scamp73
          • Dec 2011
          • 95
          I have an extra 5s 3500mah Sky Lipo I am not using on anything right now. Is there much difference in speed from 4s-5s? Besides changing the plug end to accept 1 battery would I need to make any other changes? Bigger ESC? Disconnect the BEC? Anything else? I don't want to fry anything and cannot afford a larger esc at this time.
          • Cinnabun
            • Jun 2013
            • 433
            If you cant afford to fix it, dont run it on the edge
            • Scamp73
              • Dec 2011
              • 95
              Ya, that is pretty much what I was thinking.
              • Shovelnoserc
                • Mar 2012
                • 221
                It's all trial and error. What works for one might not work for the other. If you are going to try it. Do short runs check your temps and prop accordingly.
                Otherwise what's the C rating on these 5's? I'm down to 1 5s. As left one in the car and it is PUFFED. Hasn't one down in a week now. Might be in the market for a new pair.
                • Scamp73
                  • Dec 2011
                  • 95
                  Just pulled it out. It is a Sky Lipo 5s 3300mah 30c 60burst and is in very good condition. No puffing... May be willing to trade for something or sell. All of my boats run on 4s.
                  Miss Elam
                  SVr
                  Revolt 30
                  • erickyam
                    • Sep 2013
                    • 14
                    Im running my revolt with a m545 on 4s with stock electrics and it made a big diference. A freind of mine with smaller prop and a 2200 leopard t180 delta force 26 where side by side. So just change the prop and you will see.
                    • 4sdash
                      • Sep 2013
                      • 54
                      there is a pretty big difference between 4s and 5s i dont even run my revolt on 4s any more and well im trying to keep up with cinnabun's beast of a revolt i might try and put a 3674 2650 in the boat but i dont know how it will run
                      • Scamp73
                        • Dec 2011
                        • 95
                        4sdash-did you mae any changes to go to 5s?
                        • 4sdash
                          • Sep 2013
                          • 54
                          speed controller ,different prop but cinnabun basiclly built this boat for me he would be the right oe to ask my friend
                          • Cinnabun
                            • Jun 2013
                            • 433
                            4s's boat has a seaking 120, X445 (detongued, cupped, sharpened and balanced), OSE upgrade shaft, sharpened all the hardware, re-routed and bigger water lines, dropped the tabs a tiny bit and brought the strut up 1mm.
                            He wants to drop in a leopard 3674 2200kv and run 4s. I keep telling him to leave well enough alone.
                            • BHChieftain
                              Fast Electric Addict
                              • 1969
                              If you want 5S, highly recommend a 120-180A ESC and a smaller prop.
                              Chief
