Removed Battery Tray
  • JLShip
    • Jul 2013
    • 74
    Removed the stock battery tray it was Cracked/Spilt, replacing with Fiber-Glass Tray. Question any easy trick removing white Adhesive that held the battery tray from factory?
    Not going to Carbon Fiber hull, want to run two 1 1/2"x12" wide med weight F/G cloth , Above new F/G battery tray and between the strakes. Pulled Foam from bow, going to use pool noodle.
    Any help would be appreciated.
    Jim
    Question: I've never worked with Caron Fiber, will Z-poxy finishing resin work , Do you scuff the shinny area on carbon fiber when you placing it on the resin?
    Might use a Carbon Fiber Battery in the Revolt instead of the F/G Battery tray ?
    RC Grandpa
    NAMBA Dist. 9
    Folsom R/C Modeleers
  • JLShip
    • Jul 2013
    • 74
    A friend I called, explained that finishing resin, would work for the purpose that I was going to use it and that Carbon/Fiber would work on the F/G hull of the Revolt..
    Thanks
    RC Grandpa
    NAMBA Dist. 9
    • Margeibel
      • Jul 2013
      • 29
      Where did you find that battery mount? I have the same problem with my tray and needs to be replaced.
      Thanks M
      • Cinnabun
        • Jun 2013
        • 433
        I want to add a layer of cf inside my hull and put a cf battery tray in it. Just need to order my stuff up.
        • JLShip
          • Jul 2013
          • 74
          Thanks M
          Our local OSE, make sure you get the 200mm C/F
          RC Grandpa
          NAMBA Dist. 9
          • Margeibel
            • Jul 2013
            • 29
            Found it Thanks
            • skeeler
              • Jul 2007
              • 198
              JLShip,
              Your boat looks good. What technique did you use to get the old tray out? It seems difficult to get around it to cut the white silicone, given how close the edge of the tray is to the edges of the opening in the hull.
              Thanks.
              Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
              '09 Miata.
              Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
              • JLShip
                • Jul 2013
                • 74
                Originally posted by skeeler
                JLShip,
                Thanks.
                No tricks, just worked at it, pulled it slowly, start in a corner.
                RC Grandpa
                NAMBA Dist. 9
                • skeeler
                  • Jul 2007
                  • 198
                  Thanks for the info.
                  '09 Miata.
                  • fastracer
                    • Sep 2012
                    • 4
                    I used 30lb. fishing line. Put it under the tray and pull it along. works great.
                    • Mike Caruso
                      • May 2012
                      • 940
                      I like the fishing line high pressure right where you need it to cut it loose. Good one.
                      Do It Like You Mean It .....or Don't Bother
                      • Tm27
                        • Jun 2013
                        • 40
                        That's right , just start at one corner and keep rolling it up like putty . I took steel brush afterwards then cleaned with thinner. Here is pic of cv bottom and new trays.image.jpg
                        • 4sdash
                          • Sep 2013
                          • 54
                          ^that right there is beautiful
                          • FORT-26
                            • Apr 2014
                            • 241
                            First Post here.....Just got my RxR Revolt (First Boat Also)... Pretty impressed with quality of product, but some shady assembly at the factory....Oh well, gonna tear it all down anyway, to locktite, etc...
                            My question is: If I remove my battery tray and buy the carbon fiber tray, what type of glue should I use to attach the new CF tray?
                            • FORT-26
                              • Apr 2014
                              • 241
                              5 min. epoxy or GOOP seems to be the answer. I can't decide whether to get 2 trays, or 1. It seems that the single, centered, tray would be the best setup for centering all the weight in the lowest spot in the hull. You could run 4, 5, or 6s with one tray, and only 4 and 6s with dual side trays since 2s and 3s packs will be different sizes and weights.
