Water cooling Line
  • JLShip
    • Jul 2013
    • 74
    Water cooling Line
    Question
    Just received new Revolt 30, Cooling lines not in good shape (kink) and split at fittings.
    What size are the water lines?, new 5/32 silicone, fits motor ,but pulls off a little easier than stock. 2ND ? Is there, Brass fittings with longer nibbles for the cooling ring on motor (Stock)?
    By the way what size are the fittings ?
    Any help
    Jim S
    RC Grandpa
    NAMBA Dist. 9
    Folsom R/C Modeleers
  • Mike Caruso
    • May 2012
    • 940
    I found gasoline yellow fuel line at he HS that fits nice and tight plus has a thicker wall. If Hobby shop does not have it try lawn mover shop. Sorry don't know the size.
    Do It Like You Mean It .....or Don't Bother
    • JLShip
      • Jul 2013
      • 74
      Mike
      Thanks for your replay....I remembered that when using 5/32 water line( Larger line), you can cut a small piece of the 3/32 W/L about 3/16 wide and use it as a collar, put it around the larger line, were the larger line attaches to the fitting. It gives you a tighter fit...Old Gas/ Nitro trick.
      Memory is starting to come Back......
      Being the new guy on the Dock, your reply was appreciated.
      RC Grandpa
      NAMBA Dist. 9
      • Phoebe
        • Jul 2013
        • 43
        Cooling
        JLShip, That's a great idea using the next size tubing as a band clamp. Thanks!
        Last night was the first time I flodded due to a blown line. Well, it might not have been blown.. maybe I left it unconnected. Either way bad results and a good, long swim.
