Revolt Cooling mods thread. Let's see'em.
  • metoo
    • May 2013
    • 32
    I’ve seen mention of running larger cooling lines, dual lines, larger fittings, and such and so forth. I would like to see pics of cooling mods you guys have done to your Revolt. If you have before and after results, that's all the better.
    Revolt 30, Octura M545, Spectrum DX3S tx, ORX rx, Shaft from Kinetic...not on the water yet.
  • Mike Caruso
    • May 2012
    • 940
    Nothing fancy turned motor cooling jacket to exit top and bigger I.D. lines. No Issues with stock motor and ESC on Grim 4S. The Gallery has pictures of everything I have done to my Revolt. No problem with battery tray but look close plywood on each end but not touching the hull. (Tip from Grim)
    Do It Like You Mean It .....or Don't Bother
    • dirtnsnowrider
      Great Basin Aquaholic
      • Apr 2012
      • 314
      Ask and you shall receive. I have updated the lines to Dubro large #204 fuel tubing and added a secondary water pick up off the back of the transom where you bolt the strut arm mount to the hull. Hope this helps you out.
      • metoo
        • May 2013
        • 32
        Where does the hot water exit?
        • dirtnsnowrider
          • Apr 2012
          • 314
          I have 2 water outlets on the left side of the boat.
          • rickwess
            • Apr 2013
            • 777
            Just an upgrade to 5/32 tubing and proper thru hull fittings. Stock motor and SeaKing 120A ESC both running warm to the touch (but not worth measuring) with a Octura m545 prop.
            • metoo
              • May 2013
              • 32
              Originally posted by rickwess
              Just an upgrade to 5/32 tubing and proper thru hull fittings. Stock motor and SeaKing 120A ESC both running warm to the touvh (not worth measuring) with a Octura m545 prop.
              I was thinking about going with a Seaking ESC if for nothing else but to control the LVC. Man, this cheap boat is starting not to be so cheap, but so is the case with all my RC vehicles.
              That ought to be an interesting sight. Where are you guys getting those outlet fittings? What are they called officially?
              • rickwess
                • Apr 2013
                • 777
                The SeaKing's are much more linear than the stock ESC as well.
                • dirtnsnowrider
                  • Apr 2012
                  • 314
                  the water outlets on my revolt are from aquacraft part number aqub9519. I have also used aluminum antenna holders in the past as water outlets.
                  • dirtnsnowrider
                    • Apr 2012
                    • 314
                    That ought to be an interesting sight. Where are you guys getting those outlet fittings? What are they called officially?[/QUOTE]
                    check out this video to see what the dual outlets look like on my revolt, its the chase boat in this video (solid blue metallic)
                    • rickwess
                      • Apr 2013
                      • 777
                      Here you go:
                      http://www.offshoreelectrics.com/pro...prod=aero-2011
                      http://www.offshoreelectrics.com/pro...prod=aero-2014
                      • mannytx1
                        Fast Electric Adict!
                        • Oct 2012
                        • 99
                        100_0302.jpg100_0303.jpg100_0304.jpgHi, Mike grimracer zaborowski
                        I think there are serious problems with the design of the rudder, the water pickup hole is very high, need 1 inch below ( the water pickup hole should be no less than one inch below the keel) very small rudder, a minimum recommended length is 1 times the diameter of its support below Lx 15% 30”x15% = 4,5” minimum. (REVOLT 30 ONLY 4")
                        LVC not protects the batteries
                        thank you very much
                        Manny
                        • rickwess
                          • Apr 2013
                          • 777
                          Not why you think it's a serious problem. Running a m545 prop and neither the ESC or motor is getting warm enough to warrant anything but a finger measurement.
                          • Doby
                            KANADA RULES!
                            • 7280
                            thank you very much
                            Manny
                            Again, where did you come up with the calculation to prove to yourself that a problem exists when there really is none??
                            Grand River Marine Modellers
                            • dirtnsnowrider
                              • Apr 2012
                              • 314
                              thank you very much
                              Manny
                              a bigger rudder = more drag
                              the boat handles excellent with the stock rudder and does a more than adequate cooling job. This is a very popular boat and sure there are a few tweaks to make it better but the bang for the buck is there. As for the lvc not working properly. Have you checked your batteries. Many a time somebody will not balance their packs when they should (every time for cheap china packs). You said the lvc did not protect the batteries, what exactly happened. What were the cell readings after the run? Just trying to help out.....
