new speed control broken???
Post #9,
I am pretty sure,
It is a tx and program problem.
If the motor ran two times at high rpm's.
I had that happen to me a very long time a go.
I think the esc is seeing the tx in the neutral position, As high throttle.
And not as neutral position.Last edited by lenny; 04-02-2013, 12:21 AM.Comment
One last thought...don't mean to offend...these ESC only work on 4S...wanted to double check that's what you're plugging in.This is NOT a toy?!?Comment
You shouldn't need to buy another controller. You simply need to work with the settings in your controller. I would suggest this... (assuming your still using the Futaba radio)
1. Make sure you have your throttle reversed
2. Plug in batteries and you will hear one beep (higher pitch)
3. You will pull to full throttle you should hear another beep (same tone) IF NOT keep the throttle pulled and change your throttle trim and End Point Adjustments (EPA) until you hear that beep.
4. once you find the right setting and you hear the beep go to neutral and you will hear three beeps.
This process will take some time, lots of trial-n-error, and you will be unplugging and re-plugging in the battery a lot. Once you get the right settings, write them down so you don't forget.
Later,
MikeComment
Yes, that is it, exactly. I have the "stock" Tactic rx/tx, and from what I read on this forum, I set the throttle trim at 2:00 (it was already at that position, right out of the box, but I checked anyways). Plugged in batteries ... beep, pulled trigger to full throttle ... beep, back to neutral ... beep, beep, beep, pulled trigger and prop spins and steering works. Tried throttle a couple of times (based on what you said your's did, above), and it worked as expected every time.Comment
So another member here walked me through setting it up and turns out its not broken and seems to work perfect but before all that i talked aquacraft and he said it was bad and sent me a new esc so i guess i will have a spare. its atleast good to know that auqacraft had good customer report on trying to help and sending out replacement partsmiss geico 29,revolt 30,villain ex,summit,scte,8ightComment
Malfunction in helmet in racing terms.Comment
Well I deleted the current model out my controller and stared from scratch and started by turning my trim down but didn't help so I turned my trims up and got basically all the to the end of the trim before it beeped correctly then it armed perfectmiss geico 29,revolt 30,villain ex,summit,scte,8ightComment
So trim cranked like I said 20 posts agoComment
