Hello all. I am starting this post with a brand new AQ revolt 30. I have a eagle tree v4 logger with GPS. For each logged run I will use the same pair of batteries, they are sky lipo 5000 mah 35c 2cell. They are about a year old maybe 15 cycles on them. The logger pics are the max seen by the logger. In time I will learn how to graph my reads but for what I am showing this will do for now with that said here I go. Yesterday I took the revolt out of box charge the batts put logger in and took across the street for a run batts side by side to the back of the tray, I changed nothing. The first pic shows a speed of 35.7 The next day I changed to a grim racer L45 x 68 the speed went up to 38.8 the boat porpoised real bad. The high rpm reading on second run must be the flip it took. Thursday when I am off I will try removing foam from battery tray and mounting bats low and on top of each other then I will start trimming. I will log each change and do only one change at a time to show how much of a difference it made.
Eagle Tree readings on my new revolt
That's why I bought mine. I have Eagle Tree in mine also. the boat is stock except for 3-m pad the bottom, Hughey prop shaft, 5.5 battery to ESC connectors, wood added to battery box ends front and back but do not touch the hull, prop shaft straight with bottom of hull Grim 4s battery and last time out 52 mph my best with Octura X-642, 2nd best M-545 = 50 mph, If I remember 45.7 with 45x68 and 40.0 with stock prop. Battery moved all the way back in the box, only lowered one inside right rear trim tab until it is even with the hull.
I have galley pictures and I guess you can search my name to find out what I am forgetting. Best of luck to you and just a great boat. I am still learning the ET graphs myself.
Mike Aeromarine cable drive nutDo It Like You Mean It .....or Don't BotherComment
Here is a recording of my stock Revolt 30 w/ M545 prop w/ aftermarket flex drive. I was surprised to see that full throttle runs were not blowing the stock electronics (1500 watts and 100+ amps). Temps are warm but not excessive. I ordered a GPS expander, I can't wait to see how fast this setup goes (just how accurate is GPS anyway?).
Anyway, my first FE and I am hooked!
Revolt 30 Octura M545.jpgComment
Now with a Carbon Fiber 45mm X 1.4 Pitch Prop
Same setup. The boat is alot slower, but amps/watts are still up there with a little more run time left in the battery. I can't wait for the GPS unit to show up.Revolt 30 CF 45mm 1.4 P.jpgComment
Eagle Tree GPS Unit info
Bummed. I was sure my stock Revolt 30 with the Octura M545 was doing more than it was.
Fresh batteries were good for 45.8 mph. I was sure I was getting more.I guess I need to sharpen/balance the prop even more.
I learned on thing, the carbon fiber 45 X 1.4 prop is worthless, 38.5 mph with about the same battery drawdown with the same run time.
The carbon fiber 42 X 1.4 was good for almost 34 mph. However, I can run for 7 minutes with that prop and still have 20% left in the batteries.
Ran out of daylight so tomorrow I"ll throw the stock grimracer 42 X 55 prop and see what she does.Comment
IR temp gunned the motor (laser pointed into the motor can by the motor leads) at 135F right after popping the hatch. Batteries and ESC around 105/110F. So far everything is holding up...Comment
Good way to cook the electronics with the constant on and off full throttle.
Don't think you let it run WOT for more than 20 seconds anywhere in there.If my boats upside down then who owns the one I thought I was driving the last two laps?Comment
Look at the amp spikes from the constant on and off the throttle, your amp draw when running is low, it's the repeated spikes that are going to damage things. Not the low draw when running.
There is nothing at all to be gained by testing or running a boat like that, just going to burn up the esc spiking it like that every 10- seconds, not even long enough to get the boat running stable to see how it is actually set up and running.If my boats upside down then who owns the one I thought I was driving the last two laps?Comment
