Anybody have an easy way to replace the stock battery tray. Mine has come apart and there is no stock replacement.
Better battery tray?
white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Tags: None -
i seen somewhere on here a guy yanked his and put some of the battery trays from ose in the bottom as he used one battery all the time here is what he used http://www.offshoreelectrics.com/pro...=ose-80525-140Im Only Responsible For What I Say Not For What You Understand -
Thanks. I've seen those but was just looking for a drop in. I'm going to use the cf batt tray I have here, put some notches in it for straps and epoxy it in. Ill shoot a pic when done.
Thanks again.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
Hi stadiumyamaha,
OK, as you want.
I'd like to ask you: for you the Rev.30 is really good boat, did you had some problems with it?
I'm planing to buy a new boat and I really don't want to repeat the mistake of purchasing the Spartan.
Now, I'm following what the people say on this forum about Rev.30 and it seems that the Rev.is what i need.
Thanks, Niky.Comment
The revolt like most aquacrafts have some really cool things about it and some things I hate. Like the battery tray. But I think that will be the case with any rtr. I sort of like my spartan but know its limitations. It's a great basher on 4s with a big prop.
The revolt is really fun once set up. I've put a ul1 motor in mine and it really goes now. One of the coolest things about it is its so light that if you set it up right it will run a very long time on one 4s 5000mah battery with zero heat issues. With my set up I'm getting the best all round performance running a x642 prop.
If you get one make sure you check every fastener on the thing. Mine and others have had an issue with this.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
Sorry I didn't understand what you wanted to say in the last line.
Anyway when I buy it I intend to convert it to 6s (T ESC 180A+Leopard 1600KV motor).
I got just the 3s (6 pacs), another bad memory of Spartan, wanted to go fast and then burned ESC.
OK, thank you again salute Niky.Comment
This is what I came up with to replace the stock tray that failed. Should work well, sits low in the hull and has good stem to stern adjustability.
