I noticed today when installing my flex cable back into the collet that the motor shaft and rotor moves a tiny bit forward and back when applying any pressure on it.When I first got it I remember having to pull on it a bit and push kind of hard to get the stock flex shaft in and out of the stock collet with the stock cable before I upgraded to OSE shaft and Octura collet.Motor seems to run fine but I noticed on my motley crew motor the shaft does not move at all forward and back.It is not much movement but I can look inside and at the bearing in the back and notice it move maybe a mm or so.Motor spins just fine and feels just like the MC motor in resistance.Should I be ok or what do you recommend I do.
I will make a video tommorow and show exactly what it does.
Thanks,
Brandon
Thanks,
Brandon
