Revolt30 battery
  • Revolt30
    • Sep 2012
    • 32
    Revolt30 battery
    Whats he most battery voltage you can use on the Revolt 30? Using 2-7.4(14.8V) 5000 mah 50C now.Can you use more then 14.8V or will it just burn things up?
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    if you have the stock esc here are the specs for it
    SPECS:
    Length: 3.25" (83mm), Width: 1.5" (38mm), Height: 0.3125" (17mm), Weight: 3.8oz (109g)
    Wire Gauge: 14 gauge
    Max Output Power: 720 watts
    On-Resistance: 0.003 ohms
    Low Voltage Cutoff: 11.63V, Thermal Cutoff: 230 degrees F (110 degrees C)
    Stutter Bump Voltage: 12V
    Operating Frequency: 8KHz
    BEC: 5.2V/2A
    Timing Angle: 10 degrees
    Battery Connectors: Male Deans Ultra Plug Connectors (2)
    Motor Connectors: 4mm Gold-Plated Bullet Connectors (3)
    Input Voltage: 12-14 NiMh 4 Cell Lipo (8-20V inout w/o BEC)
    Output Current: 60V Continuous Maximum with a 72A Surge Maximum rating.
    Im Only Responsible For What I Say Not For What You Understand
