My Revolt 30 - "Bold Skull"
I just ordered the x642 today from Hazegry. Meanwhile I gave some positive (up 2mm from stock setting) to the prop strut looking to rise the bow a little and try to gain some more speed. Trim tabs at 0 degrees now. I had the chine walk dialed down to a minimum when I started this thread, lets see how it behaves with the new strut setting. I will run the boat tomorrow and report back. After tomorrows's run it will be time to re-lube the prop shaft so I will be installing the thrust bearing then.Last edited by gyrotron; 08-13-2012, 09:07 PM.Comment
Cricket Creek Forest Preserve just outside of Chicago you have to get a license and be a member of IMPBA or NAMBA. I belong to the Badgers Club in WI also great bunch of people.Do It Like You Mean It .....or Don't BotherComment
For some reason I thought you were in the FL area I did not pay attention to your location tag. I am not affiliated to any club yet, I just boat on a pond close by my house.Comment
That would be nice I have to drive min 20 miles to run or to WI 65 miles.Do It Like You Mean It .....or Don't BotherComment
Came back from today's run. Here are some pics of the pond near my house where I go boating.Attached FilesLast edited by gyrotron; 08-14-2012, 12:42 PM.Comment
Hi, Gyrotron, Beware,even if you use loctite on the Bullet nut the heat from the flex shaft in the strut bushing will let the bullet nut loose and it will come off sooner or later. Do yourself
a favor. Install the normal lock nut then the bullet nut in back of it. Regards
Norman234" Ekos Cat UL-1 PoweredComment
Norman2.
Meanwhile I gave some positive (up 2mm from stock setting) to the prop strut looking to rise the bow a little and try to gain some more speed. Trim tabs at 0 degrees now. I had the chine walk dialed down to a minimum when I started this thread, lets see how it behaves with the new strut setting.... I need some help
here folks since I have never replaced a brass tube and or applied epoxy before, let me know what I need to do and how do I remove and clean up de existing epoxy to make the fix.
Do you guys think the Revolt needs an adjustable stuffing tube bracket? it is a fully adjustable bracket for 1/4 brass tube. It has adjustable height, angle and if installed with spacer washers can be adjusted side ways also. I found this piece at Kintec racing and it is used for the Motley Crew.
hhttp://kintecracing.com/Motley_Crew.htmlLast edited by gyrotron; 08-20-2012, 09:22 PM.Comment
No where yet. Still working on my sv restoration. Taking my time on it as its my first gut and redo. The revolt is still waiting on the backer and for me to go over evrything with loctite. After reading on here for a long time finally decided to try boats. Have friend thats been trying to get me to run them at maximo park in St. Pete but its salt water.Comment
