Is This Normal???
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Is This Normal???
    Not sure if this was design that way.
    Can you guys check your boats and tell me if your rudder is offset the same way mine is?
    Thanks
    Robert
    Canada
  • Doby
    KANADA RULES!
    • 7280
    Not Normal.
    Grand River Marine Modellers
    • LiPo Power
      • May 2009
      • 3186
      Hmmm, looks like another project over the winter....
      It was mounted that way. Will this create problem on the water?
      Hope not much....
      Canada
      • stadiumyamaha
        • 1284
        Mine is not like that.
        white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
        • LiPo Power
          • May 2009
          • 3186
          Mr Grimracer, what is your take on this please?
          Canada
          • Doby
            KANADA RULES!
            • 7280
            Hope not much....
            You won't even notice it the way you drive......
            • Darin Jordan
              • 8335
              Can't you just loosen the bolts and straighten it out? Looks like fairly normal "mounting slop" to me... If the holes are clearanced correctly, and assuming the holes in the transom are drilled correctly, that could be simply a matter of loosening the bolts and moving the rudder back to vertical.
              Darin E. Jordan - Renton, WA
              • LiPo Power
                • May 2009
                • 3186
                With all the weeds in our pond acrobatic driving is recommended or I loose the rudder out on weeds anyways...
                Canada
                • LiPo Power
                  • May 2009
                  • 3186
                  Bolts and rudder holes are drilled tight, no room to move.
                  From what I see after removing the rudder the holes are not drilled properly. They out of line so I will need to fill one up with epoxy, paint and drill again to fix it.
                  I will only do the buttom one to be able to move it little closer to the prop shaft.
                  Little that I have to do this with new boat.... Why mine???
                  Canada
                  • Darin Jordan
                    • 8335
                    Well... in lieu of getting a replacement, I'd probably opt to just slot the holes in the mounting bracket or open them up so it can be rotated back vertical. Not ideal, but in the end, the important part is for the rudder to be vertical.... You'll want to use some larger diameter washers to cover up the open up'd holes...
                    • LiPo Power
                      • May 2009
                      • 3186
                      Thank You Darin...
                      Easier and quicker I guess...
                      Canada
                      • Darin Jordan
                        • 8335
                        Thank You Darin...
                        Yup... Further, you would only be modding the rudder bracket... MUCH easier to deal with! Definitely will improve your driving if this is vertical!! Then Doby might quite giving you $hit... :D
                        • Doby
                          KANADA RULES!
                          • 7280
                          Or you could just do the simple "bend it back in shape" protocall......
                          • Darin Jordan
                            • 8335
                            That's assuming that the bracket it bent... I know that the Speedmaster stuff sometimes bends at the bracket, so that's possible... Personally, I wouldn't want to put that kind of stress on the transom. I'd open up one or both of the holes and just adjust it accordingly.
                            • Doby
                              KANADA RULES!
                              • 7280
                              Personally, I wouldn't want to put that kind of stress on the transom. .
                              Whimp.....
